Results 1 to 9 of 9
    Feb 29 2016
    Bellevue, Ia
    Speedometer correction
    So currently our speedometer is reading off by a about 3 miles an hour is there a way to correct this?
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    Change your tire size
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Off at what speed? Mine gets slightly further off the faster I go... At 40mph on the speedo its only off maybe 1mph, if that. At 80mph on the speedo I'm about 77-78 on the gps.
    Tire size and wear can also contribute. Example because math:
    Standard tire is 235/40-R18. Say new tread depth is 10/32", and your tires are worn with 4/32" left.
    new tires diameter = 25.4"
    worn tires diameter = 25.025"
    difference: (10/32 - 4/32)*2 = 12/32 = 3/8"
    circumference new = 79.8"
    circumference old = 78.6"
    difference: 1.2"; so for each rotation your worn tire actually travels 1.2" less distance. Meaning it needs to spin faster to go the same speed as the new tire.
    At 70mph, new tires rotate 927 times per minute. The worn tires would need to rotate 940 times. Since the speed sensor just counts rotations, the car thinks you are going faster with worn tires than you really are.
    New tires at 940 RPM would be 71mph, so in this example your speedo would read 71mph when you are actually traveling 70mph.
    ...aaand that's not as large a difference as I was hoping lol. Oh well, I always wanted to figure that out.
    If you had the wrong size tires (smaller diameter than OEM) you can really be off. I had a friend with a truck a long time ago that threw on some small wheels for some reason once and it was hilarious, speedo was reading like 95mph going the highway and we were really only going maybe 70-75.
    Also, I've heard before manufacturers calibrate it to be off 1 or 2mph anyway to cover any measurement error/legal reasons, so they should never read slower than actual speed. But I don't know if this is true or not.
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Feb 29 2016
    Bellevue, Ia
    We just put on brand new 235 40 18's and it's still off? I thought it would be closer with the new tires but it doesn't seem to be! I wasn't sure if there was a way to change tire size in the computer of the car?
    Oct 02 2005
    The Moon
    There isn't any adjustment that can be done to alter displayed speed.
    However if you want a more true reading 245/40/18 would be best.
    Feb 29 2016
    Bellevue, Ia
    Well crap that's would have been better to know last week.
    Veteran Member Three Rings luvsspeed's Avatar
    May 13 2007
    04 S4
    North Carolina
    Quote Originally Posted by pchrist View Post
    Mine is the same and I've checked by radar/lazer. All but one of the vehicles in my household are off 1-3 mph. From my understanding no speedo will be 100% accurate and will be off by 1-3 mph. Anything more than 5mph would be a reason for concern.
    Feb 29 2016
    Bellevue, Ia
    Ok good to know I was running Waze and it came up like 3 mph off made me wonder
    Jun 07 2013
    West
    Nothing to correct. Designed that way.
