I just lowered my car and I love the look, but I have a set of 20's I want to put on the car. I am currently running OEM RS4 wheels (19x9 ET57 with a 255/35/19) and have no issues at all, even with the car being lower now. I tried to test fit the 20' and it did not even come close to fitting because it hit the suspension arm. It is a 20x8.5 ET33 with a 255/45/20. Do any of you know if I switch the tires to 255/30/20 that they will work. I did the calculations and by going with a 30 sidewall on the 20 inch wheel I will actually make the overall diameter smaller (26.03 for the 19' and 26.02 for the 20') The offset is low at ET33 and that is where I want to know if I would clear the fender. I would think that having the rim only be 8.5 wide that it would help with the poke. Any thoughts? Can anyone confirm or is anyone running this set up? Thank you.
