Hello people,
Problem:
I have serious problem with my Audi A4 B6 2.0 Petrol with CVT trans.
My car was working normal, even CVT was all right, no PRND warning lights, no rough acceleration, jerking etc.
Suddenly my speedometer died. Id measures max to 50-60 km/h. After that trans starts to jerk, engine struggles with it, revs go up and down, really not drivable. Below 50km/h it works normal.
On the highway i switched to multitronic mode, and manually shifted to (virtual, since its CVT) 6th gear. That way i can drive 120km/h+ (measured with GPS), but speedo still shows 60km/h.
As i said, i can manually shift even in urban driving conditions and it is (almost) drivable, but still speedo not working, and driving in D is not good.
What i tried:
What I tried so far is that i lifted the car up, drained CVT fluid, removed TCU, opened it to check for some burns or cold solders on computer board, and everything is fine. I checked sensors for input and output shafts, and they both work as they should.
I properly closed TCU, put it back, filled CVT fluid back into trans. Car works exactly as it did before i did this.
I checked all error codes in both engine, abs and transmission, before and after lifting the car. There are no errors in any of them.
As you can see i totally don't know what to do. My car is in garage for few weeks now, i dont drive to prevent any further damage.
I would appreciate any help from you people!
