Results 1 to 14 of 14
    Oct 24 2015
    Perth, WA
    Recommendations on a B7 2.0T DV relocation kit or DIY?
    Hi guys
    Done the research etc, seen multiple posts, manly for GTis and B6s however I am looking for recommendations for preferably a 'bolt on' DV relocation kit to work with my K04.
    If not, a parts list of the best stuff to use.
    Any help appreciated.
    Thanks guys!
    My respray thread
    Oct 24 2015
    Perth, WA
    bump - anyone?
    My respray thread
    Oct 24 2015
    Perth, WA
    Disappointed guys :)
    Surely someone has a parts list required or a kit recommendation?
    Bumpity?
    My respray thread
    Dec 23 2011
    For a K04 size turbo I'd stick with a GFB DV+. I had no issues with it when I had an F23L turbo. If you really want to go a different route try a Synapse DV. That is what I currently have for my GTX2867r setup.
    Synapse DV will require 1" fittings to be installed in piping pre turbo & post turbo for 1" silicone hose to be connected to with the Synapse DV in-line. You'll also need to have an additional boost tap into the intake manifold
    Feb 08 2012
    Dallas, GA
    Quote Originally Posted by p0isin View Post
    Second this, I don't have a K04, but I might in the future. Just get the GFB DV+ with the longer bolts for the K04. I loved the change in response when I swapped it out on my (apparently) leaky K03.
    May 05 2014
    B6 A4, B7 A4 and B8 A5 all R Black
    Adelaide Australia
    You could use the S3 OEM or Golf R OEM if you are not using an after market / performance intake, I went with the Unitronic relocation kit and modified it to fit my intake non OEM
    Oct 24 2015
    Perth, WA
    Ive just pieced together the parts separately. Not cheaper, but was easier in the end.
    My respray thread
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Synapse DV is an awesome product. Sounds amazing. I used in on the K04, GTX 2863 and GTX 2867. Great product. Some silicone hoses and fittings and you can relocate it to the intake side too.
    Oct 24 2015
    Perth, WA
    Yeah I have the GFB+ DV and I now have all the silicon, adaptors etc to relocate to the TB side.
    My respray thread
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by Okedokey View Post
    For others inquiring could you provide where you purchased and what you used?? I've seen a few relocations done. But not really sure everyone has, but an update on parts used and cost might be a good thing for this community. I like the idea. I think the only benefit for me wud be more sound but I cud be wrong it may actually react different on the TB side.
    Oct 24 2015
    Perth, WA
    I will put up a DIY when I get all the parts. The benefit is colder air recirculation, less chance of surge and clearly, in the case of many KO4s, DV installation on compressor housing is not an option.
    My respray thread
    Jun 17 2013
    jersey city nj
    It is on my APR KO4
    Oct 24 2015
    Perth, WA
    Yeah, the cold side vent is a better option anyway.
    My respray thread
    Established Member Two Rings lowlife89's Avatar
    Jun 01 2013
    EU
    Just FYI you can use these plugs:
    - 8D0973822
    - 1j0973722A
