Results 1 to 21 of 21
    Veteran Member Three Rings TylerT's Avatar
    Jun 07 2016
    San Diego
    Need help identifying coolant leak (Pictures inside)
    Hello everyone,
    Just hoping I can get some guidance here, If I posted in the wrong subforum I do apologize in advance.
    My 6MT S4 is just about at 119,000mi and after leaving work last Friday, I noticed a large pool of coolant under the car. When I put the cooling system under ~15psi via the expansion tank, It's tricking down heavily on the driverside of the transmission area. Not a drop of coolant on the passenger side.
    I verified the expansion tank does have a slight crack (replacement on the way, very slow leak) , although the majority of the fresh fluid seems to be pooling around this area in the pictures below, pretty much where the engine & transmission connect. The hole you see is circled in this picture:
    Driverside:
    Any ideas?
    2001.5 S4 6MT - F21s & E85
    2004 Cayenne Turbo - Beater
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    Id check the coolant rail in the back. It could be leaking from the head
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    It might be the drivers side heater core hose connection to the hard pipe
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Check the crossover pipe as mentioned above, and check the block valley to see if coolant is pooling up there. There's a ton of seals that can leak back there. Best to pull the intake and refresh everything at once.
    2005 A4 Avant 1.8t QTM
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    It's probably your auxiliary coolant pump. When the pump goes it will fill the valley and leak out whichever way is easiest.
    As stated above; check under your intake.
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    Check under intake but most likely coolant crossover or temp sensor
    01.5 Imola S4. Stage 3 F21's/To much to list
    Jun 07 2016
    San Diego
    Thank you for all the helpful responses,
    I looked under the intake manifold with a flashlight and I did see some signs of dried up coolant, I'd say the auxiliary pump is a good place to look first.
    I'm picking up some intake manifold gaskets today from a local shop and last but not least, a Bentley service manual
    Aug 24 2014
    Newport Beach, CA
    I can tell you that, coming from someone aka me that had coolant leak from both the auxiliary pump as well as the heater hose connector on the back of the engine, that looks much more like the heater core hose coupler leaking.
    2024 M3 Comp xDrive
    Jun 07 2016
    San Diego
    Curious, was the leak obvious and in plain visible sight? What part # on this diagram are you referring to?
    Thanks much!
    Dec 16 2014
    Irvine, CA
    Rear main seal flange could be leaking as well, that paper gasket always fails.
    Veteran Member Four Rings QuinnsterKID's Avatar
    Mar 02 2010
    1989 Ford Mustang LX 5.0
    Las Vegas
    Just a tip..... if you pull the coolant hard line running on the back of the cylinder heads, make sure you replace every O ring that attaches to it. Especially the one the goes on the pipe that runs to the front of the block. That will also fill your valley. Once an O ring has been pulled they do not seem to reseal the same as if they were new. Trust me.
    2012 Moonlight Blue S4 // Black Optics // Intake and Exhaust // Lowered
    2001.5 Nogaro S4 // 6MT // Stage 3 // K04 // E85 // Daz tuned
    2014 Daytona Gray Pearl Q5 TDI // Black Optics // Sport
    2013 Black A4 Sport SOLD
    2008 Ibis White A6 3.2 Quattro SOLD
    2004 Silver USP A4 Avant 6mt SOLD
    2000 Laser Red A4 1.8 Quattro SOLD
    2001 Santorin S4 SOLD
    Jun 07 2016
    San Diego
    You guys were right, Auxiliary water pump appears to have leaks everywhere. After pulling the manifold, I put the expansion tank under pressure and there's a steady stream of fresh coolant in this area.
    Also, appears to have been happening for some time considering the insane amount of dried coolant that has pooled.
    I also managed to break both lines that connect to the rear if the manifold (PCV spider hose and something else?) ... damn brittle plastics
    Either way, learning experience! I'm excited to get 'er back on the road. ,
    Jul 04 2012
    Woodbridge, VA
    Relocate that sucker to the back of the engine.
    Veteran Member Four Rings jballou's Avatar
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    Quote Originally Posted by vavJETTAw36 View Post
    Why?
    2000 Audi S4 Stage 3,000 Million +
    Some crap just thrown together, puzzlingly making more power....
    YouTube Channel: http://www.youtube.com/user/jsballou
    www.tvme.info
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by jballou View Post
    Why?
    More horsepower!
    Just messing around. Easy access for when it leaks again. Yes, it will leak again. When? Who knows. But you'll be able to swap it under 10 min
    Nov 05 2009
    Denver
    For the once every 10-15 years you would need to change the pump, is it really worth the effort to relocate? No.
    Jul 07 2009
    Alberta, Canada
    Agreed.
    Aux pump is one of the simpler tasks on these cars.
    Jun 07 2016
    San Diego
    Replacement parts are on the way, installation looks to be a breeze.
    Maybe somebody could point me in the right direction .. what are the 2 intake manifold connections on the back?
    One of them connects to the PCV spider hose, not sure about the other one.
    Thanks a million guys.
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    Quote Originally Posted by Zba View Post
    Exactly.
    www.tvme.info
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Spider hose and brake booster
    Jun 07 2016
    San Diego
    Leak fixed, tested 15 psi for 15 minutes and there wasn't a drop in the bucket.
    Time to jerry rig some vacuum hoses and order a few replacement pieces.
    Thank you everybody for the help!
