Results 1 to 3 of 3
    Aug 09 2016
    2002 A4 3.0 6 speed manual
    Wyoming, Michigan
    Transmission fluid and differential fluid change???? HELP!
    OK so I have a 2003 A4 quattro 1.8t 5 speed automatic. I want to change my trans fluid and differential fluid. The questions I have are. What fluid does the trans use and how much, how many differentials are there and what fluid do they use and how much? I get conflicting stories on everything I read online. Thanks for any help you can provide.
    2003 A4 1.8T Stock
    2002 A4 3.0 6 speed Manual Stock
    May 02 2015
    2007 S4 DTM
    WA
    "The last of the V8 Interceptors... a piece of history!"
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    I would also take a look in your owners manual. I changed mine in my 6MT B7 S4 it was very easy with the right equipment. Auto is a little different, but the diff should be the same. Good oil does help a lot!
