Results 1 to 4 of 4
    Jun 19 2011
    2013 VW Golf R
    long island
    Changing front break pads
    Looking to change my front break pads to something that is low on dust. I was looking around on a DYI and didn't find anything,is there anything I should know that might be special to these cars? I done breaks before, is it just pull caliber off and just replace the pads? Thanks
    2000 Audi A4 Koni coil over,Flik wheels, MTX sound system.
    2013 VW Golf R,UM Stage 2 tune,CTS intake and heat shield,Autotech HPFP,Sigma 6 speed short shifter,neuspeed front mount intercooler and delete bracket,APR turbo back exhaust with cat,BSH throttle pipe,CTS turbo pipe,US Millwork tow hook license plate holder,H&R lowering springs
    2016 Audi S3 floret silver,LED, Sports seats, resonator delete, stock location K&N filter, posi quit front break pads
    Aug 08 2016
    Quote Originally Posted by lamchop View Post
    Fronts are pretty standard but its an Audi not a Honda so torque it all to specs. Rear is a pain because of the ebrake from what I've read. For the rear you're suppose to use a vag com but I'm pretty sure you can just disconnect the battery and/or remove the plug for the ebrake. Just don't push the piston in get the right tool to screw it back in
    Senior Member Three Rings miro01's Avatar
    Mar 26 2012
    '97 B5 A4, '15 8V A3
    OC
    Pretty straightforward. The pad wear sensor is on the passenger side. The harness clip breaks easily.
    Sent from my SM-G900T using Tapatalk
    Jul 09 2013
    Montreal, Canada
    Which "low dust" pads are you going to install?
    2018 RS3 | Unitronic catted downpipe & midpipes | CTS IC |
    Stock: [email protected]
    Unitronic ECU stg 1+ (93oct.): [email protected]
    (SOLD) 2015 S3 Tecknik | Eurodyne ECU Stage 2 93 & TCU Stage 1 | CTS catted downpipe |
    Eurodyne stg 1.5 93: [email protected]
    Eurodyne stg 2 93: [email protected]
