Originally Posted by
MarlinFoundNemo
What is the relay number rollerton?
I can't remember on the S4 exactly...but on the C5 it's almost always the relay at the very top - left corner of the relay panel.
Here's a pic of it jumped- but if you push the little tabs on the plug you can release the relay plug, slide it out so you can get to the wires on the back and splice into the connection. On the C5 I think the ground signal is actually the one with two small black wires going into one connection.
The wires should be two large gauge red wires (one 12V+ BATT feed to the relay, one RED is the 12V on one side of the starter circuit and then one large RED/BLACK that goes out to the starter. The ground closes the circuit between the 12V and the starter allowing the starter to turn).
Here's a pic of the relay connector bypassed.
