Oh how time flys when you aren't focused on a project!
So had a tough time finding the right size metal fittings to go from the catch can to the braided lines. I finally found some coolant pipe barbs on Rockauto that were a perfect match! So I tossed some thread tape on the lil bastards and got to work.
I mounted the can to the core support. The mounting bracket wants you to screw in from underneath, going to the side of something. I imagine to have a "floating" look to it. I found that if I were to do that, the can would be sitting to low and cause the lines to bend too much at that angle. So I bent the bracket flat and mounted it that way...
Once I got the can sitting right, I started routing the hoses and trimming just the right amount to fit the bends right...
I'll probably find some kind of line management system (aka zip ties) to try and group the 3 lines together in a more cleaner fashion. Right now, they kinda look like an octopus or squid is trapped under the hood...
The next step is to actually pull the intake manifold for another cleaning of the valves. And then retest a year from then to see if the can helped.
Anyway... project complete!
