Yesterday evening, after work I had an hour of time to fix my problem.
Started with these things:
1- Released the hydraulic tensioner again to tension the timing belt
2- Fastened the cam sprocket bolts
3- re-attached the lower timing belt cover
4- installed the crank dampener pulley
5- removed the crank lock tool
6- checked TDC and camshaft lobe positions
This is when I realized I indeed made one stupid mistake, I was 180 degrees off and the lobes were pointing down instead of up like in these pictures:
7- removed camshaft locking tools
8- rotated the crankshaft until the engine was in the right position
9- installed camshaft locking tools again, engaging way way better than before
10- wiggled the crankshaft untill all camshaft locking tools fit snug
At this point all camshafts were perfectly locked down by the cam locking tool, except one.
The
passenger exhaust camshaft was off and not fully engaged by the locking tool, first I thought this made sense since the VAGCOM reading said one camshaft position was 19 degrees off.
But this was a BANK 2 camshaft according to VAGCOM and if I'm not mistaken this is the drivers side cylinder head right?
Passenger side:
Driver side:
Anyway, this was a problem, the camshaft should be correctly locked down by the locking tool so went on with my procedure:
11- removed crankshaft dampener and lower timing belt cover again
12- loosend the camshaft sprocket bolts
13- removed tension of the timing belt by locking down the hydraulic damper
14- partly removed timing belt
15- bolted down the camshaft sprocket bolt of the passenger side exhaust camshaft until the camshaft was now fully engaged by the cam locking tool as well.
I think succes
Engaged like it should:
One thing I can't explain is why the VAGCOM reading said the camshaft position of bank 2 was of while the exhaust camshaft of passenger side was off.
Unless this is untrue:
Bank1 = passenger side
Bank2 = drivers side
