We're pleased to announce the availability of our all-new 8V Audi A3 FWD Adjustable Solid Rear Sway Bar! These bars feature one-piece solid spring steel construction and two-way adjustability, and are in-stock and ready to ship.
Adjustable MQB Solid Rear Sway Bar Upgrade, MkVII Volkswagen Golf/GTI, 8V Audi A3 FWD
Retail: $265.00 + Shipping
034Motorsport is proud to offer the ultimate rear sway bar upgrade for the MkVII Volkswagen Golf/GTI & 8V Audi A3 FWD! The 034Motorsport Adjustable Solid Rear Sway Bar is made from a single piece of high-quality, 25.4mm thick spring steel for maximum rigidity, and is designed to combat understeer while reducing body roll under hard cornering.
This product was tested thoroughly on the street and track on 034Motorsport's 2015 Volkswagen GTI Development Vehicle and multiple enthusiast-owned MQB Audi/Volkswagen vehicles before release. The 034Motorsport Adjustable Solid Rear Sway Bar substantially reduces understeer and body roll on 8V Audi A3 FWD & Volkswagen Golf/GTI vehicles without compromising comfort on the street.
In addition, the 034Motorsport MQB Rear Sway Bar is engineered to be used effectively with the stock front sway bar. No upgrade in the front is required. The addition of a stiffer front bar can positively affect turn-in feel, but ultimately worsens the platform's tendency to understeer. With the stock front sway bar and upgraded 034Motorsport Solid Rear Sway Bar, body roll is virtually eliminated while turn in and off throttle oversteer are greatly improved.
Features:
  • 25.4mm Diameter
  • Solid Spring Steel Construction
  • One-Piece Design
  • 2-Way Adjustable
  • Designed to be used in conjunction with the stock front sway bar.
What's Included:
  • 034Motorsport 8V Audi A3 FWD & MkVII Volkswagen Golf/GTI (MQB) Adjustable Solid Rear Sway Bar Upgrade
  • Polyurethane Sway Bar Bushings
  • Billet Aluminum Sway Bar Brackets with Integrated Zerk Fittings
  • Sway Bar Bracket Installation Hardware Kit
Fitment:
  • 2015 - Present Audi A3 FWD (8V - MQB)
  • 2015 - Present Volkswagen Golf/GTI (MkVII - MQB)
Sway Bar Rate Data:
  • 034Motorsport (Soft) - 153% Rate Increase vs. Factory (20mm) Rear Sway Bar
  • 034Motorsport (Stiff) - 174% Rate Increase vs. Factory (20mm) Rear Sway Bar
Installation Instructions:
Please Note: We recommend upgrading to our Spherical MQB Audi A3 & MkVII Volkswagen Golf/GTI Rear Sway Bar End Links to gain the maximum performance benefit when installing this rear sway bar upgrade.
Available at these 034Motorsport Dealers near you:
New German Performance - Maryland & Virginia
Please don't hesitate to contact us via PM or email if you have any questions!
You May Also Be Interested In:
MQB Audi A3/S3 Dogbone Mount Insert
MQB Audi A3/S3 Spherical Rear Drop Links
X34 Audi A3 Air Intake System (Carbon Fiber)
