Originally Posted by
texasboy21
7.5" is 190mm, and 8" is 205mm.
I agree that going too wide on a wheel is detrimental, but sticking with the same width seems a bit narrow.
The "ideal" tire setup is a bit narrower than most would go with, usually one or two sizes lower. A very slight stretch, but nowhere near to the extent that you would see on a stance car. It helps a lot with sidewall stiffness and steering response. Though typically if you get tires where your wheel width falls near the middle of the tire's recommended wheel width range, you'll be golden.
The taller your sidewall is, the more you can get away with going wider. However, you're also going to introduce a lot of slop and lazy handling feel.
I think an ideal setup for the weight of these cars would be something like an 17x9 with 255/40r17 tires. That way you can fit wide enough tires to handle the weight and improve handling, keep a similar amount of sidewall for comfort. Of course, these aren't really sports cars so audi went smaller in the name of cost and fuel economy.
