Results 1 to 12 of 12
    Jan 16 2016
    Los Angeles, CA
    Recommended shop that can help install an RS5 Trunk on an S5
    Hey guys,
    Wanted to ask if you guys can recommend a shop that can help me install an RS5 boot lid on an S5? Any help would be appreciated. Thanks in advance!
    Veteran Member Four Rings tcm glx's Avatar
    So Cal
    Supreme Power in Placentia.....call and ask for Tam or Erik. Great guys, tons of experience.
    2013 Audi Q5 2.0T Premium Ibis White/Chesnut Brown
    2018 Audi Q7 3.0T Glacier White/Nougat Brown
    Veteran Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    I'm sure Boden can handle this.
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Wicked Motorsports on Sepulveda Blvd in Van Nuys. Talk to Mike. He does lots of custom installs and specializes in Audis.
    Tell him Christopher Barzman referred you.
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    are you talking about just a trunk lid swap or the electronic spoiler deployment mechanism as well?
    Jan 16 2016
    Los Angeles, CA
    Quote Originally Posted by MikeyB3 View Post
    The electronic spoiler as well. I have everything but the wiring for it, so I was wondering if a shop would be able to help me out on that.
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by FightOn! View Post
    Definitely talk to Mike at Wicked. He will tell you if it can be done.
    Jan 16 2016
    Los Angeles, CA
    Quote Originally Posted by AvantNoir View Post
    Will do. Thanks for the recommendation. I'll mention you referred me.
    May 22 2007
    Santa Monica CA
    I'll actually be seeing him tomorrow and will mention it to him.
    Jan 16 2016
    Los Angeles, CA
    Sounds good! Thanks! Let me know what he says.
    May 22 2007
    Santa Monica CA
    First, he said he thinks you've called him.
    As far as the install, yes can be done. Integrating it the way it works on an RS5, throttle/brake activated can be done, but VERY expensive to do wiring. He said he could do it, but rolled his eyes when discussing cost and said it wouldn't be worth the cost to do it.
    My thought was to just connect it to a switch on the dash/console to trigger it manually. Mike also suggested to have it connected to a WOT switch so when you're on the gas full throttle it would deploy.
    Hope this helps.
    Jan 16 2016
    Los Angeles, CA
    Hope this helps.
    Ahh I see. Yeah I figured it might cost a bit too much. Maybe I'll just wait it out and save the mod for next year.
    Thanks again for helping out. I appreciate it!
