Results 1 to 7 of 7
    Dec 10 2013
    ga
    Engine making roaring noise when pressing on gas
    Hey guys.
    I have a 99 audi b5 1.8t. I noticed that a"roaring noise" occurs when I press on the gas or driving from 1st to 3rd. It doesnt make the noise unless I press on the gas.... even when I am in park. Its not the wheel bearings as I have changed those recently. I also notice that my car doesnt make a wind-down noise anymore when I shut off the car. I checked the fans and both are running so I'm not sure what it could be.
    Please Help.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    No check engine light/ codes?
    And to be clear it happens even when parked? Have you had someone press on the gas while you are outside the vehicle to see what general area in the engine bay the noise is coming from?
    2016 S3
    Instagram- @Thisisastickup
    Dec 24 2010
    2001 A4 4.2 v8 swap, MR2 Turbo, CBR1000rr
    Columbus, Ohio
    exhaust leak?
    Dec 10 2013
    ga
    Yes when I press on the gas, it makes a roaring sound coming from the engine. It idles fine but when I give gas or begin to accelerate...it makes that sound. I have no check engine lights and the car hasnt overheated either. Also I dont hear the wind down sound I usually hear when I turn off the car.
    Some suggested it could be the fan clutch that is jammed.
    Dec 10 2013
    ga
    I havent ruled that out but the sound is coming from the engine bay. My exhaust sounds fine.
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Loose heat shield?
    Dec 10 2013
    ga
    No loose Heat shield. They are tightly secured
