Results 1 to 8 of 8
    Active Member Two Rings Quaality's Avatar
    Jun 06 2016
    '08 G8
    Minnesota
    Lower control arm advice
    So had my mechanic take a closer look to front end today since I've been having noise up there for some time and can not find the source of it. Called me back this afternoon and said after some time of looking at the struts and shaking down the front end and transmission (just replaced mounts on transmission about a month back, still missing the bar that goes along bottom, can't find a replacement sold anywhere). He said that after a little while he found a little play in the lower control arms, more noticeable the left side than right, with some pressure he could get it to click a little, so he was saying that it was his best guess. So, I guess it's time to do arms even though I've owned the car less than 5,000 miles. So do I Just do lowers or do all of them? Do I replace other things with the arms? and what tools do I need for the job? I can wrench a bit and seen a few guides, all looks like a lot of work, maybe over my head, limited on tools so not sure if I can do this myself. I noticed that a few guys dropped out the shocks (is this normal? hard to put back in?).
    *as a side note*: I am a little budget minded as I have an oil leak to chase down still in the car, looking like maybe turbo lines or a bad seal or two. depending on location of leak I could be in the market for doing a timing belt/water pump job at the same time.
    -All advice needed and helpful, thank you peoples.
    Current Vehicles: 2001 A4 1.8T 5 speed, 2008 G8, 2001 F250 Powerstroke
    Dec 10 2013
    Borden, Ontario, Canada
    Grab an entire FCP control arm kit and do it that way. Replace a of them at once. The entire kit would run $250 shipped to your door with a lifetime warranty.
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jun 06 2016
    '08 G8
    Minnesota
    could you link the kit you recommend? the one I found a guy on the forum used was from blauparts. however this one is a bit pricy.
    Veteran Member Four Rings B5nDisciple's Avatar
    Aug 23 2014
    2006 Honda Odyssey--Cannondale Caad 12--Giant Talon
    Tucson
    http://www.audizine.com/forum/showthread.php?t=679455
    I'm running the same kit with no issues. Can't go wrong for the price and lifetime warranty...
    Sent from my VS990 using Tapatalk
    Then Jesus said, “Come to me, all of you who are weary and carry heavy burdens, and I will give you rest." Matthew 11:28
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    x3 FCP
    -----> CLICKY < -----
    SOLD the GOINHAM A4 ---> GT2860 Project
    Senior Member Three Rings DoesntCare's Avatar
    Feb 28 2016
    SEPA
    Are the "heavy duty" arms that are available considered not worth the money?
    Jun 06 2016
    '08 G8
    Minnesota
    Thank you for links. What's the difference from the standard 13 piece to the option3 version. And do you recommend doing struts at the same time? Car has 140k miles.
    Nov 17 2011
    Fredneck Maryland
    Quote Originally Posted by Quaality View Post
    option3 version ? not sure what that is?
    struts yes if you need them and most likely you do @140k. If your going coils or something soon just wait for that.
    this --> $228 vs this ---> $317
    Looks like different tie rod ends I meant to send the link for the 228 kit
