Page 1 of 3 123 LastLast
Results 1 to 40 of 94
    Nov 02 2006
    Alot of junk
    MD
    MIR Track Rental Friday 10/28/16
    Now that the weather is cooling off I decided to rent both lanes at the best track around, MIR. One line will be for drag radials and slicks only. Other lane will be for street tire cars. Cost will be $100/car for unlimited runs from 9am-5pm (track isn't usually prepped and ready to go until around 10am). If you don't like waiting in long lines at test and tunes and want tons of runs to practice this is the event for you! Plenty of knowledgeable friendly people to help as well. Ever wonder what your car runs in the 1/4? Here's your chance. Who wants to have some fun???
    Low and slow
    Nov 29 2013
    Silver Spring, MD
    Cross posted in the B8 Forums (1/4 mile thread). Boost season!
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Registered User Four Rings
    Jun 25 2016
    DMV
    who's got light wheels and sticky tires for me to do a run or two in the SQ
    Senior Member Three Rings classicj's Avatar
    Jan 15 2015
    B7 A4 2.0T, Tiguan, BMW Z3M Roadster, Ford F350
    DMV
    Excited for this
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Quote Originally Posted by classicj View Post
    Excited for this
    Gonna break Tiguan records? 😎
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Damn I have a 12 hour work day that day.
    Jun 25 2016
    DMV
    Quote Originally Posted by JimmyBones View Post
    i did NAWT see that coming!!!!!
    Nov 02 2006
    Alot of junk
    MD
    You said pick any weekday (since you can't make the Saturday rental). I said will a Friday work and you said yes. So this was the first Friday available. Sorry you can't make it.
    Low and slow
    Dec 18 2014
    DMV
    Damn! Sucks. Well, there's always the Saturday rental.
    Established Member Two Rings drivenagain's Avatar
    Sep 05 2016
    MD
    man dont pull me back in...
    Nov 02 2006
    Alot of junk
    MD
    Quote Originally Posted by drivenagain View Post
    Too late!!!
    Low and slow
    Apr 08 2004
    Washington, DC
    That's crazy how you know the hours you have to work well over a month in advance. Not that you have to work that day, but that you know you're on the clock for 12 hours.
    Quick, whatcha doin on November 14th. :P
    991 / C7 / M3P / 5.0
    (Former Audi's: 2015 SQ5, 2013 Allroad, 2012 A4, 2001.5 K04/GIAC A4)
    Sep 05 2016
    MD
    Quote Originally Posted by blackbenzz View Post
    Too late!!!
    i think so
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    Quote Originally Posted by Ty Webb View Post
    lol
    Eurosport Tuning at it's Finest
    Apr 03 2010
    Northern Virginia
    Yeah I wasn't expecting to have a long distance big church event scheduled during the mid afternoon.
    I know that you are messing with me but I had told blackbenzz that I would most likely be able to do a Friday morning and early afternoon. Right before my post I double checked my schedule to confirm if I was going to keep to my plan and that is when I realized.
    Probably doing my inspection and prep for going to the dragstrip the 15th. Why, do you want to come over and lend a hand?
    Apr 05 2015
    '86 Porsche 944, '73 Dodge Charger, '07 Audi RS4, '01 Audi S4
    Urbana ,MD
    I just got a 67 Coronet with a 440 that I'm going to set up to be a drag car. Wonder what it will do, tempting. Trying to get into the 10s eventually
    Sent from my SM-G900V using Tapatalk
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    I will be there on the 14th for the TNT session...hopefully we wont have a 2 hour brake clean up like last time I went
    [B]Current: Shopping now....
    Nov 02 2006
    Alot of junk
    MD
    Quote Originally Posted by Dan_G View Post
    Good time to find out
    Low and slow
    Apr 05 2015
    Urbana ,MD
    If I can get off work. I expect it to run mid to high 14s in its current trim. Would be nice to have a solid baseline. Should be making only 250hp 400tq currently with 2.91 rear gears.
    Nov 02 2006
    Alot of junk
    MD
    Baseline is good. Then you can track how far you've come
    Low and slow
    Apr 05 2015
    Urbana ,MD
    Any recommendations for a proper chassis setup in general before adding power
    Nov 02 2006
    Alot of junk
    MD
    Not sure what you mean by proper chassis setup
    Low and slow
    Apr 05 2015
    Urbana ,MD
    As in general alignment specs, shock valving, springs rates. Nothing too specific just what works and doesn't in general. Everything I've done before has been for autox or track and seems counter intuitive in a drag car.
    Apr 03 2010
    Northern Virginia
    Do you expect the front end to come off the ground?
    Nov 02 2006
    Alot of junk
    MD
    You want soft rear so it squats. Not a lot of negative camber in the rear either as you want as much contact patch as possible. Some do positive camber so that when it squats it's at zero
    Not if its a 14 second car
    Low and slow
    Apr 05 2015
    Urbana ,MD
    Thanks, nothing I can do in the rear in regards to camber as it's a solid axle. I guess soft rear also means shocks that compress easily for better weight transfer and easier to extend fronts.
    Any recommendation for a 15" 275 dot drag radial?
    Oct 31 2005
    Ashburn
    My participation is Tentative atm. I never made any strip events last year but I have more of a reason to come this time
    - Instagram: @Sinister_rs5-
    Nov 02 2006
    Alot of junk
    MD
    Correct on the suspension. Now if it's a dedicated drag car things change but we are talking sub 8 second territory. You don't want the fronts in the air and you get sensors that cut power and keep the front tires about an inch off the ground. I've seen my friends viper go down the track with the front tire barely touching the ground through the process. You obviously can't steer it that way and that's when suspension geometry becomes absolutely critical
    Woohoo! Hope you can make it
    Low and slow
    Dec 18 2014
    DMV
    You should definitely go! run a faster time than I did because you would do it right. Apparently you have to turn off AC and Radio...lol
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
    Nov 02 2006
    Alot of junk
    MD
    Cooler weather is upon us
    Low and slow
    May 26 2008
    MD
    Boost weather
    Oct 31 2005
    Ashburn
    Quote Originally Posted by Evilevo View Post
    Boost weather
    Ditto!
    Jun 25 2016
    DMV
    someone lend me some light wheels and sticky rubber to do a run or two??
    Oct 31 2005
    Ashburn
    I'll need to practice some launches with the car before attending. Haven't launched a Audi since my B5 S4 days.
    Nov 02 2006
    Alot of junk
    MD
    Can practice as much as you want at the track!
    Low and slow
    Jun 25 2016
    DMV
    plus its auto haha. hold down brake hold down gas let go of brake, right?
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Quote Originally Posted by agautohaus View Post
    Honestly curious as to how one launches a ZF auto; it cant be as simple as "green means go, stomp on gas" right?
    2015 B8 SQ5
    Click Here
    Past
    Jun 25 2016
    DMV
    Nah it's a little different.
    Hold down brake hold down gas let go of brake it squats and gives you a few seconds to let go of the brake. At least I know al the Q's do it
    Don't forget, slow... ZF comes in the RS6 and RS7! That means we basically drive RS6's!!!!!!!
    Oct 31 2005
    Ashburn
    A google search has revealed that however I'd rather experience at least once before hand lol! It said something like it needs to be in Dynamic and sport/manual mode and the rest is basic, hold brake pedal, press gas it revs up to 5k rpms, release brake and enjoy sub 3 sec 0-60 times
    May 26 2008
    MD
    Time to put a RS6 badge on it!!!
