I tried using the Ball Joint Separator Tool from Harbor Freight, but this time around, the tool broke and snapped. It tried the pickle fork, didn't get through; I took the control arm from the subframe side, and now is resting on the floor whereas the ball joint part of the rearward lower control arm is still stuck to the spindle.
Do I need to continue working with a pickle fork here? Or should I try another Ball Joint Separator? I noticed there is no room for using an air hammer here due the axle boot in the way; also can't use heat.
Other suggestions would be greatly appreciated.
This is the last segment for my suspension rebuild on the driver side; hopefully Passenger-side will go smooth.
Thanks again
