Results 1 to 3 of 3
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    Questions related to programing for 6sp swap
    Some coding issues to work through related to the 6sp swap..
    The ABS isnt working, and the shop believes its related to fault codes indicating the car is still looking for an auto trans (TSU), and not finding one.
    I have looked through 6spd swap threads, but havent seen anything directly related to this.
    Im looking to basically direct the shop on how to code the car to expect a manual trans. Basically any coding in VAG comm that should be done when a 6spd swap is done, id like to review.
    Option 2 will be to have Unitied Motorsports take care of this when i get the car tuned by them.
    Thanks all!
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    I had the same issue. Abs needed to be reprogrammed before the swap when there was no code in the system. Now it wont let you reprogram it. I ended up swapping one from my manual donor car.
    So you have two options, swap manual abs from a donor car or put yours into running AT car and then reprogram it to manual.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Jun 11 2013
    Ok that's great info.. I'll look into option tomorrow. Appreciate it!
