    Need help! Coolant pipe/water hose
    I am in desperate need of a coolant pipe for my s4. All the dealers around say that it's on back order from germany.. this is hard to believe, but reguardless..
    Part number: 06E121045AE
    This number is the same as the one that ends in "Q" instead of "AE". The AE is just and updated version. Either will do..
    I already contacted ECS to see of they could source the part but they don't know if they can. I hoping somone out there is parting out a wrecked 3.0T...
    Pic:
    Using Tapatalk
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Just curious if you broke off the little nipple? I did a fix on mine that i posted http://www.audizine.com/forum/showth...s-very-brittle
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Quote Originally Posted by infinkc View Post
    Close.. the small piece that has the seal around it that goes inside the thermostat literally disintegrated when I pulled the pipe
    Using Tapatalk
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by DUMPMOUT View Post
    if you cant find one pm me, the dealer by me had one not too long ago when i repaired the pipe.
    I just sourced one from a dealership in ohio. Not that far from NY should be here by wed if all goes well. Keeping my fingers crossed. Thanks for the help. If this falls though I'll hit you up. Nice write up on your repair by the way👍. These plastic pipes are brutal.
    Using Tapatalk
