Results 1 to 16 of 16
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: No More Inconvenience!
    Electronically monitored oil level on newer Audi's sounds like a great idea in theory, but what if you want to manually check your oil level? ECS Tuning has recognized this issue and designed our Billet Engine Oil Dipsticks to not only provide you with a more dependable option, but also an attractive addition to your engine bay.
    6061-T6 Billet Aluminum handles are finished in two color choices (Polished & Black Anodized), and feature a stainless steel bullet shaped indicator designed to match up with the OEM specified 'Low' and 'Full' oil level marks on the dealership special tool
    No more inconvenience
    Fits:
    Audi B8/B8.5 A4 2.0T 2009-2016
    Jason
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Did we test this one on an A4? And with an OEM engine cover?
    I've had the old one in my trunk for nearly a year now waiting for this redesign.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    +1 returned mine due to the fact it stuck up and pressed into my hood liner plus incorrectly read I was overfilled. So has this in fact been redesigned and actually tested??
    Oct 02 2006
    Wadsworth,OH
    Yes the handle has been redesigned to allow for more hood clearance.
    Jason
    Oct 23 2014
    Buffalo, NY
    Jason
    Has the overall length of the dipstick been adjusted?
    °2011 A4 | 6MT
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by bakedziti View Post
    This dipstick has been completely reworked from the previous one. Measurement adjustments have been addressed as well as over all height when installed.
    Jason
    Oct 23 2014
    Buffalo, NY
    Jason
    °2011 A4 | 6MT
    May 24 2007
    PA
    Sorry to report but this dipstick made a cut in my hood insulation. It looks to be rubbing against the hood liner.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by s4baby View Post
    Do you have the older style with the round pull or the new updated version that is flat on the top?
    Jason
    May 24 2007
    PA
    Jason
    I have the same one as pictured above with the flat top.
    Oct 02 2006
    Wadsworth,OH
    Can you PM me some pictures of it installed and the damage to the hood liner? Also there is two different dipsticks one for up to 2012 models and one from 2013, can you also list what year vehicle you have as well as your order number?
    Thanks.
    Jason
    Oct 23 2014
    Buffalo, NY
    I received my replacement with the flat handle, but I have to say that it certainly appears that this hasn't solved the issue, because the handle is still higher than the engine cover.
    Maybe it's just me, but why isn't this designed to sit below the engine cover? Or, why not remove the piece between the bottom of the handle opening and the top of the plug?
    °2011 A4 | 6MT
    Oct 02 2006
    Wadsworth,OH
    The revision wasn't intended to have the handle sit below the cover. It was to allow for more clearance of the hood. It sits well below our carbon fiber engine cover which sits higher than the factory cover and doesn't hit. You should be fine with clearance.
    Jason
    Senior Member Three Rings t28sentra's Avatar
    Nov 18 2007
    B8.5 Allroad ,B6 S4, B5 S4 (Imola - Sold), B6 A4 USP , B5 A4 Sold, Laser B5 S4, Jeep Wrangler (Sold)
    Toledo, OH
    Jason,
    Are their any plans to take care of the people who ordered the original model which had clearance issues? I removed mine a month after purchase and would like to exchange for the updated model.
    B8.5 Allroad (APR K04 E85), B6 S4 (JHM Goodies), B5 S4 Imola Avant (JHM RS6-R), Touareg V10 TDI, B6 A4 USP (REVO Stage 3) SOLD, B5 S4 (EPL Stage 3 on Meth) SOLD
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by t28sentra View Post
    Jason,
    I called and had them send this new one after the old one sat in my trunk for almost a year.
    Thanks Jason.
    °2011 A4 | 6MT
    Oct 02 2006
    Wadsworth,OH
    Jason,
    Yes, please contact customer service and they will set you up with the revision dip stick.
    1-800-924-5172 ex 134 or [email protected]
    Jason
