Results 1 to 9 of 9
    Jan 29 2016
    Worcester/MA U.S.A
    Angry B6 quattro wont start. TCU issue?
    Ok for some time My A4 has not been working. one day it just legit just starting sputting out and then puff now it wont start. To be honest with you people i'm like 110% lost on this i have a VAG-COM 409. It's kinda wonkey but it works. The last scan shows this... the front end was taken apart so some codes might just be BS. It sat for some time and i tried working on it the other day and i almost started it then it gave up. If someone knows WTF there looking at and can guide me through this i was immensely appreciate it. (responses to dumb A** standard plz)
    VAG-COM Version: Release 409.1-S
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
    Address 01: Engine
    Controller: 8E0 909 559 D
    Component: 3.0L V6/5V G 0002
    Coding: 0016751
    Shop #: WSC 13873
    2 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 002 - Lower Limit Exceeded - Intermittent
    17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
    P1564 - 002 - Lower Limit Exceeded
    Readiness: 0110 1101
    Address 02: Auto Trans
    Controller: 8E0 927 156 J
    Component: AG5 01V 3.0l5V USA 0808
    Coding: 0001002
    Shop #: WSC 63351
    1 Fault Found:
    18164 - Tiptronic Recognition Switch (F189): Open or Short to Plus
    P1756 - 003 - Mechanical Failure
    Address 03: ABS Brakes
    Controller: 8E0 614 517 A
    Component: ABS/ESP allrad 1726
    Coding: 04497
    Shop #: WSC 00000
    3 Faults Found:
    18258 - Powertrain Data Bus: Missing Message from ECU
    P1850 - 35-00 - -
    18034 - Powertrain Data Bus: Missing Message from TCU
    P1626 - 35-00 - -
    01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
    35-00 - -
    Address 09: Cent. Elect.
    Controller: 8E0 907 279 E
    Component: int. Lastmodul RDW 0204
    Coding: 00001
    Shop #: WSC 00000
    4 Faults Found:
    01518 - Bulb for Back-Up Lights: Left (M16)
    57-00 - Electric Circuit Failure
    01502 - Bulb for Rear Fog: Left (L46)
    00987 - Lamp for Brake Light: Left (M9)
    01501 - Bulb for Blinkers: Rear Left (M6)
    Skipping Address 15-Airbags
    Address 16: Steering wheel
    Controller: 8E0 953 549 L
    Component: Lenksáulenmodul 0308
    Coding: 01141
    Shop #: WSC 63351
    No fault code found.
    Address 17: Instruments
    Controller: 8E0 920 950 H
    Component: KOMBI+WEGFAHRS. RB4 D22
    Coding: 01123
    Shop #: WSC 01120
    WAULT68E82A085820 AUZ6Z0A0116397
    6 Faults Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    30-10 - Open or Short to B+ - Intermittent
    00562 - Shareware Version. To Decode all DTCs
    27-10 - Please Register/Activate - Intermittent
    01314 - Shareware Version. To Decode all DTCs
    49-10 - Please Register/Activate - Intermittent
    01315 - Transmission Control Module
    49-10 - No Communications - Intermittent
    01316 - Shareware Version. To Decode all DTCs
    01320 - Shareware Version. To Decode all DTCs
    49-00 - Please Register/Activate
    May 20 2010
    Everything I'm seeing points to an electrical problem. Probably something grounding related. My brother's old allroad starting killing sensor after sensor because the grounding bars below/around the battery corroded away. I would start by clearing the DTCs, and with a fresh battery connected up, seeing if they return. If they do, check the condition of those bars. May need to remove some rusted bolts, chase the threads with a die, tap the threads into the body (ground) and hope that closes the circuit.
    Jan 29 2016
    Worcester/MA U.S.A
    OK sorry I haven't been on replaying or even working on the car but i got some free time today. So I made some progress on the car... Well some its starts and revs but dies right out. I'm going to go in to as much detail as I can possibly can. So bear with me, The PRNDS on the cluster goes out every now and then. But everything else on the Cluster shows perfect, but when the PRNDS does not show it seems to correlate with the car not wanting to start. I can't keep the car on more than a couple revs. Also along with this nightmare of errors. The MPH needle likes to jump around sometimes and the dash likes flicker on sometimes. I’m going to post a video on this post so maybe u guys can get a better look at the situation on hand. The front end is kind of taken apart so some things on the dash will show like headlights and etc.
    https://www.youtube.com/watch?v=qR5LOY93oYw
    Jan 29 2016
    Worcester/MA U.S.A
    I also noticed something wrong when I press the gas pedal in PRNDS disappear also. When I let my foot off the gas it seems to be back to normal but the car still won't start.
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    I wonder if your tiptronic shifter magnets are messed up?
    Some strange things happen when the magnets break off from the shifter gate.
    Jan 29 2016
    Worcester/MA U.S.A
    I replaced them from another car at the junkyard. But yeah they don't work either.
    Jan 24 2010
    Paramus,NJ USA
    B6 wont start. TCU issue?
    If the car does not start you need to start with the basics.Is the engine timed correctly and spooning freely??Do you have fuel at the fuel rail???Do you have spark at the ignition coils???If you have all 3 engine should start.The TCM will not cause a no start.mu suggestion is clear all the faults out of it and start from scratch.
    Judging purely from the noise it's making its possible that you have a fuel supply or ignition issue.
    Also the cluster should not go out when cranking.Make sure you have good ground on the engine and battery.
    Ziddy Autowerks
    Veteran Member Three Rings mosnet99's Avatar
    Oct 10 2015
    2004 USP 1.8T, 1993 Jeep Cherokee Country
    Detroit, MI
    Got alot of issues going on there in the scan but I just wanna say I spent a few days trying to figure out my own cranking but no start (one time it started then died like in the video) issue. Had no codes on mine but it ended up being a small metal particle on my crank sensor that was throwing off timing. I just replaced the sensor.
    Sent from my LG-H811 using Tapatalk
    Misfiring 2004 1.8TQ USP, CX Racing FMIC, Hybrid K04, Milltek HFC
    Jan 29 2016
    Worcester/MA U.S.A
    Hey thanks a lot for all your help i'll look in to all your ideas ASAP. But tbh i was focusing on the TCU more then anything. I'll start girding our some test soon. but again thanks a lot.
