Ok for some time My A4 has not been working. one day it just legit just starting sputting out and then puff now it wont start. To be honest with you people i'm like 110% lost on this i have a VAG-COM 409. It's kinda wonkey but it works. The last scan shows this... the front end was taken apart so some codes might just be BS. It sat for some time and i tried working on it the other day and i almost started it then it gave up. If someone knows WTF there looking at and can guide me through this i was immensely appreciate it. (responses to dumb A** standard plz)
VAG-COM Version: Release 409.1-S
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 559 D
Component: 3.0L V6/5V G 0002
Coding: 0016751
Shop #: WSC 13873
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 002 - Lower Limit Exceeded
Readiness: 0110 1101
Address 02: Auto Trans
Controller: 8E0 927 156 J
Component: AG5 01V 3.0l5V USA 0808
Coding: 0001002
Shop #: WSC 63351
1 Fault Found:
18164 - Tiptronic Recognition Switch (F189): Open or Short to Plus
P1756 - 003 - Mechanical Failure
Address 03: ABS Brakes
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04497
Shop #: WSC 00000
3 Faults Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-00 - -
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 35-00 - -
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-00 - -
Address 09: Cent. Elect.
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0204
Coding: 00001
Shop #: WSC 00000
4 Faults Found:
01518 - Bulb for Back-Up Lights: Left (M16)
57-00 - Electric Circuit Failure
01502 - Bulb for Rear Fog: Left (L46)
00987 - Lamp for Brake Light: Left (M9)
01501 - Bulb for Blinkers: Rear Left (M6)
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 01141
Shop #: WSC 63351
No fault code found.
Address 17: Instruments
Controller: 8E0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 01123
Shop #: WSC 01120
WAULT68E82A085820 AUZ6Z0A0116397
6 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-10 - Open or Short to B+ - Intermittent
00562 - Shareware Version. To Decode all DTCs
27-10 - Please Register/Activate - Intermittent
01314 - Shareware Version. To Decode all DTCs
49-10 - Please Register/Activate - Intermittent
01315 - Transmission Control Module
49-10 - No Communications - Intermittent
01316 - Shareware Version. To Decode all DTCs
01320 - Shareware Version. To Decode all DTCs
49-00 - Please Register/Activate
