Results 1 to 3 of 3
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    ::Excelerate Performace:: Limted Time Offer!
    WEBSTORE
    For a limited time we are offering up to 5% off on select APR products by using the promo code GOAPR on our VAG store. Promo code discounts vary per product and cannot be combined with any other offer.
    Click here or the image below to experience the online shopping experience with Excelerate Performance. Many APR products are in stock and will ship the same day.
    If you want to determine exact stock status we encourage you to contact us.
    Feel free to contact us via Live Chat, email at [email protected], or phone at 203-483-6100. We are here to answer questions! Thank you.
    If you would like to know more either call
    203-483-6100
    E-Mail
    [email protected]
    Or, check it out online
    http://vag.excelerateperformance.com/products?bid=13716
    Check Us Out on Social Media!
    Feb 14 2014
    Audi's
    Branford, CT
    These might not be in stock anymore but we have more then enough APR products in stock for other applications!
    Thanks,
    Alex
    Feb 14 2014
    Audi's
    Branford, CT
    APR has recently reintroduced a legacy product, but with a twist which means the elusive R1 diverter valve is getting a facelift. The R1 started as an investment cast construction, this has since morphed into a milled modular billet assembly. With this release Excelerate Performance has found some extra stock of the Cast version. We are blowing these out at 10% off for the remaining 15 units.
    Product Info:
    The APR R1 Diverter Valve is a critical performance upgrade recommended at all stages of performance as it replaces the failure prone factory unit.
    The R1 is designed withstand extreme boost pressures at the highest levels of performance, while offering lightning fast response thanks to the unit’s friction-free diaphragm-based design.
    Unlike piston based units that can stick and bind in the winter, the APR R1 is virtually maintenance free, requiring no greasing or o-ring replacements, as is common with other units.
    Cast housing with a high-temperature Nomex-reinforced diaphragm, the R1 is designed to be the last DV upgrade the engine will ever need!
    Click here to view the sale price on this product!
