Oddly enough, when I changed from a A6 3-spoke wheel with paddles tot he S6 wheel with heat, I now have a transmission error. The yellow gear pops up and says it's OK to drive normal but the paddles do not work. With the standard A6 3-spoke, which I swapped in from a 4 spoke originally, the paddles work fine.
I went back into VCDS to change the coding but it is still set to the correct coding for the wheel. The one thing I have noticed is the "-" on the left hand paddle does not light up like the right hand paddle for "+".
I'm thinking there may be a wiring problem and will take the wheel off and inspect but everything looked good at first glance. Anyone else run into something similar.
