Results 1 to 7 of 7
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Do I have to Remove Axle Bolt Before Reinstalling Lower Control Arm(s)?
    I'm having great difficult positioning the front lower control arm with the subframe to get the new bolt through. What could be the conflict here?
    I got the bolt 95% percent through until the edge of the other side was coming in the way. Very frustrating
    At first, I got the front lower control aligned with subframe perfectly, but then the ball joint was not getting through the spindle because of the axle boot in the way. These axle nuts are not even reusable.
    None of the Bentley Publisher Videos and Erwin Audi Service Manuals indicate removal of the axle bolt.
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    disconnect the sway bar link
    that'll give the movement you'll need
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Dec 27 2014
    2013 Audi Q5 3.0T
    The Sway Bar Link is already out of the way
    I'm relying on a rubber mallet and pry bar to help me make little adjustments here and there.
    There's very little wiggle from that front lower control arm
    I haven't gotten to removing the rear lower arm yet.
    I temporarily disconnected the tie rod, to allow me to move the spindle when attempting to fit the ball joint in.
    It was perfect getting the front lower control in the subframe prior to placing in the ball joint, but the ball joint then would not be able to insert into the spindle because of the CV Axle Boot.
    Current:
    70,xxx Miles
    182,xxx Miles
    Dec 27 2014
    2013 Audi Q5 3.0T
    Finally got the front lower control in with gentle persuasion. I had to disconnect the upper control arms from the spindle first to get more leverage. I attached the front lower control arm to the subframe first as that is a nuisance to align--then I moved around the spindle (being careful not to damage the axle boot) to align the front lower control arm ball joint. Note: the ball joint may need some adjustment for proper fitment into the ball joint socket on the spindle. There should be no reason to remove the axle bolt. There's a reason why Audi states to replace the bolt with a new bolt if the axle bolt is ever removed.
    Hopefully, someone will find my Suspension threads useful--even though they're not all in one.
    Quote Originally Posted by PaperToast View Post
    Current:
    70,xxx Miles
    182,xxx Miles
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    The axle bolt is torque to yield, meaning you deliberately stretch it for maximum clamping force. It also means it will never be able to provide the same clamping force again. Take a metal Slinky and stretch it out all the way and then let it go. It'll never return to its original shape, same principal.
    For that matter, most of the suspension bolts are torque to yield as well.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks, by the way, are all the Axle Nuts now allen-type (interchangeable between older and newer models)? Did Audi make a revision? I can't seem to find the part number for the bolt-type. I see the one on mine is a hex-bolt type aka axle bolt, not a nut. Odd...
    Quote Originally Posted by carmudgeon View Post
    Current:
    70,xxx Miles
    182,xxx Miles
    Dec 27 2014
    2013 Audi Q5 3.0T
    As it all turns out, there shouldn't be a reason to removing the axle nut / bolt when replacing the lower control arms unless the service / repair manual specifically mentions it though.
    Current:
    70,xxx Miles
    182,xxx Miles
