Results 1 to 2 of 2
    Jul 15 2014
    Cape Breton Island
    Flat spot/hesitation resolved!
    I know some of you were having the same flat spots in the lower to mid range or a jerky power band.
    Well after checking for vaccum leaks etc I almost gave up.
    Turns I found one of the spark plugs backed out 1/4 of a turn. (I just replaced all the plugs 5k miles ago)
    Anyways after re torquing all the plugs to spec and a throttle body adaption.
    The car is back !
    Did a pass down the 1/8 mile track and ran a 8.8@79mph first pass.
    Cars working great again hope this helps
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Im glad you were able to fix it!!
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
