Results 1 to 9 of 9
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    6MT Shifter wiggle
    Has anyone come up with a solution to the shifter wiggle (slight left and right play). I tore mine all apart and there is a rubber sleeve between the plastic piece that clamps to the shifter rod and the plastic piece of the actual knob. The rubber in there had sheared off causing the wobble.
    I'm going to try gluing it. Before that I wanted to post.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Jun 05 2014
    2010 A4 6MT Prestige 19" Sport
    Philadelphia Area
    Curious myself
    Sent from my A0001 using Tapatalk
    2016 S4 6MT SD BlackedOut B&O Tech
    Senior Member Two Rings gunde's Avatar
    Dec 07 2005
    Montreal
    I think you would prefer to repair it rather than replace it, but I just installed the JHM shifter and WOW. I love it.
    The oem shifter would pop out of its "cage" if I would pull upward lightly on it.
    Hope I'm wrong, but I don't think you can buy parts for the oem shifter.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Apart from replacing it with a SS I'm not sure...
    Jul 28 2009
    Philadelphia PA
    LoctiteSuper glue gel fixed it. Between the white rubber sleeve and the shifter knob insert.well see how it holds up. It's a pretty tight fit as is, I think the glue will take out the wiggle for good.
    No wobble at all at the moment.
    c8 a6 allroad
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I have an ECS short shifter and the wobble didn't go completely away but it's much much better
    Sent from my SM-G925V using Audizine mobile app
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by MrFunk View Post
    I have a short shifter, the wobble I'm referring too is in the shift knob assembly.
    c8 a6 allroad
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    No wobble on my Ghetto short shifter
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Jul 28 2009
    Philadelphia PA
    Zero wiggle now.
    c8 a6 allroad
