Tune: APR Stage 1 91 Octane
Symptoms
- STFT: -26.5
- LTFT: -8
- AFR is around 11-12when starting car before ECU adjusts fuel trims
- Boost spikes at 20 PSI in second gear and above, tapers down to 14 PSI by redline
- Poor fuel economy
- Backfires when revving
- Feels like losing power in higher RPMs when boost tapers off
Tests
- Coolant temperature normal
- Passed boost leak via Turbo Inlet @ 5 PSI
- O2 sensor is new
- FPR is new
- Compression normal
- No codes
Does anyone have advice as to where I should check next? I'm stumped lol. Thank you for your time!
