Results 1 to 4 of 4
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    Need identification of bolt under intake manifold
    I removed my throttle body today to clean it and scope the back side of the valves. When I removed it, I noticed a bolt, the one below the throttle body hole in the picture with the rubber on it.
    Does anyone know what that is for? Or if anything is supposed to be threaded on there?
    2.0T MTQ | Revo Stage II+ | APR HPFP | 034 Engine Mounts | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | TyrolSport Caliper Bushings | S4 Front Calipers/Carriers/Rotors | Goodrich SS lines | StopTech Street Performance Pads (Porterfield R4 for track) | AWE Vent Boost Gauge | NGK (4644) BKR7E (replaced NGK Iridium BKR7EIX-11)
    Oct 24 2015
    Perth, WA
    Yes, that connects to the supporting bracket for the intake manifold to the block. It has rubber on it to minimize vibration.
    My respray thread
    Mar 30 2009
    Thank you. Just had some work done and the shop probably forgot to put it back on
    Oct 24 2015
    Perth, WA
    Thats pretty lame. You want to get that sorted.
    My respray thread
