Results 1 to 19 of 19
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Installing an RNS-E H/U and have questions
    So my aftermarket head unit crapped out. My car is non-bose. My questions are:
    1. I've read that I don't need an adapter harness since my car is an 07. I only need to switch some cables.
    2. I have an aftermarket sub and I want to keep using it. What did you guys use to convert audio lines to an rca outlet?
    3. I want to use bluetooth to stream my music on my phone. Is there an adapter for this?
    Thanks!!
    Nov 15 2011
    Montreal | I sell in USD
    Switch the Kline from C7 to B5. Done.
    (By memory)
    *****I sell in USD*****
    Jul 17 2015
    miami
    Quote Originally Posted by Axis View Post
    (By memory)
    @axis thanks! Do you have a write up I can reference so identify the kline?
    Nov 15 2011
    Quote Originally Posted by miA4 View Post
    B5 for the K-Line on the RNS-E I'm 100% positive since I made an harness for my B6 last week.
    Use this for reference
    Picture of the install in my B6 because I need to whore it lol:
    Jul 17 2015
    miami
    Thanks! What about the aftermarket sub and BT?
    Nov 15 2011
    Here's the II+ to RNS-E
    And my memory was good it was C7 to B5.
    BT should be the same iirc, you might have to do more wiring if you're installing the glove box cd-changer like I have.
    Subwoofer no clue
    Jul 17 2015
    miami
    To get the BT to work, all I need to do is get the RNS-e coded for it?
    Nov 15 2011
    You already have the BT installed? If so you're probably already coded for the telephone prep.
    I'll edit with a picture of the pinout for the RNS-E quadlock and just confirm its the same on the S2+.
    Jun 27 2011
    you don't need an adapter if you're 2007. Should be plug and play after you switch the pins.
    FWIW it will work just fin without the K-line moved, but you won't be able to access the radio module in VCDS to recode it.
    It is the same. I swapped my S2+ to RNS-E with OEM bluetooth and Telephone prep and the only wiring change was the K-Line. OP you should be good to go assuming you have OEM bluetooth prep.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 17 2015
    miami
    I had an s2+ but changed to Kenwood. That one died and I have the rns-e to install. Is there an additional adalter for the BT that I need to purchase?
    Jul 17 2015
    miami
    I don't know if I have the BT prep which is what I'm trying to figure out.
    Nov 15 2011
    Remove both dome light trims, if you have a mic, you have BT prep
    Jul 17 2015
    miami
    Between Axis and Fly I would be lost without them,
    Jun 27 2011
    Alternatively, if you scan available Bluetooth channels on your phone when you turn your car on and you see Audi UHV XXXX then you have Bluetooth.
    Gonna go out on a limb and say if you don't know if you have Bluetooth, then you probably don't have Bluetooth.
    My 2008 has a crappy phone dock thing in the armrest. I'm not certain if that came with Bluetooth or some other package but chances are if you have that dock then you also have Bluetooth.
    -CP
    2017 Q7 3.0t
    Jul 17 2015
    miami
    So..... I don't have bluetooth. Is there an aftermarket option for bluetooth with this unit?
    Jun 27 2011
    -CP
    2017 Q7 3.0t
    Jul 17 2015
    miami
    Cough cough.... looks like an auxiliary plug it is
    Jun 27 2011
    Yea I actually hadn't seen Enfig's selection in a while and its dwindled a ton. I'm not sure why, but they used to have a ton of different options...
    -CP
    2017 Q7 3.0t
    Jul 17 2015
    miami
    Well I see the option for $140 and it's reasonable to an extent. I still want GPS and have to get the disc for 2015 NA which is more money... stupid radio and options
