Results 1 to 2 of 2
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    V6 3.0 TFSI Eventuri intake system under development
    Hey guys - as most of you know - us RS5 guys love the system.....Eventuri is now working on one for S5 owners.....all sales will be handled by forum sponsors who sell Eventuri :)
    See below...
    With the success of our B8 RS5 system and buoyed from the great feedback and support we received from Audizine forum members - it's time we visited the B8 S5 V6.
    Having learnt a great deal from the RS5 development - it was clear from the outset that this had to be another sealed system. The heat soak generated in the engine bay would simply negate and power gains from a free flowing filter system. Worse still - perhaps even reduce power compared with the stock system. Unfortunately many intakes currently available for this platform are open to heat soak - many have produced what seems at first glance to be sealed but on closer inspection do not seal the filter to the stock intake duct leaving it open to draw hot air in from the engine bay. Furthermore - open cone filters with heat shields also draw in hot air because the shields are not fully sealed and the cone does not directly draw in air from the duct. There is minimal airflow being forced into the duct as it terminates well above the grill.
    The Stock System
    Unlike the small stock airboxes in the RS5, the S5 airbox is a decent size which draws in air from the duct that terminates behind the front grill. The stock filter itself is cylindrical and so has plenty of surface area however the airflow path is not so smooth. Parts of the stock filter are shrouded closely by the airbox and airflow has to negotiate through several turns before ending up at the throttle body. Since the airbox is mounted to the chassis - the inlet tube has to be flexible to allow for engine movement - therefore contains ridges which are also not great for smooth airflow.
    The Eventuri Design
    As we did with the RS5 - the main component in our intake system will be our Patent Pending Eventuri filter housing. This provides a smooth transition from the filter opening to the inlet tube to maintain laminar airflow through the system. Another feature of our venturi design is the increase of gas speeds at the housing exit which allows for better throttle response.
    Here is a diagram explaining how our filter housing is so different to anything else out there:
    The effect this has on a supercharger is a reduction in drag due to the laminar flow which allows the charger to work more efficiently therefore resulting in more power.
    Unlike many "carbon" intakes, we will be using 100% prepreg carbon fibre and plenty of it! Our housing will have a 2mm wall thickness which is unheard of in this industry. This means that the carbon will be a very effective insulator from the high heat of the engine bay.
    The filter housing will connect to a carbon tube which will gradually reduce in diameter from the housing exit to the throttle body - matched at both ends.
    Finally and perhaps the most challenging part is the cold air feed. This will be 2 components, the duct and the scoop. Our duct will connect to the stock duct and then smoothly transition to the circular filter opening of the housing. It will be fully sealed to the stock duct and again sealed to the filter housing. Finally a scoop protruding down from the stock duct behind the grill will force ambient air upwards and into the intake system to ensure low IATs.
    Initial CAD Models
    More updates to follow...........
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Apr 26 2005
    Houston
    Update.....
    We will be logging the intake system and stock airbox with VAG-COM to measure IATs and MAF values. The aim is to keep IATs low while increasing the values for airflow volume. We will also do some comparison logging for the IATs between the sealed design we have VS an open design (we will remove the duct which will expose the filter).
    To enable the filter to breath better we have added a second air feed to the duct. This inlet is at the base of the duct to which we will attach an 80mm diameter flexi hose and guide it under the headlamp where the temperatures are ambient. This additional inlet ensures the filter is able to draw ambient air without the restriction of just breathing from the stock duct area.
    Here is a render of the duct design showing the secondary inlet port.
    • eCode headlights
    • Eventuri intake
