Page 1 of 4 123 ... LastLast
Results 1 to 40 of 129
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    V6 3.0 TFSI Eventuri intake system under development
    Hey guys - as most of you know - us RS5 guys love the system.....Eventuri is now working on one for S5 owners.....all sales will be handled by forum sponsors who sell Eventuri :)
    See below...
    With the success of our B8 RS5 system and buoyed from the great feedback and support we received from Audizine forum members - it's time we visited the B8 S5 V6.
    Having learnt a great deal from the RS5 development - it was clear from the outset that this had to be another sealed system. The heat soak generated in the engine bay would simply negate and power gains from a free flowing filter system. Worse still - perhaps even reduce power compared with the stock system. Unfortunately many intakes currently available for this platform are open to heat soak - many have produced what seems at first glance to be sealed but on closer inspection do not seal the filter to the stock intake duct leaving it open to draw hot air in from the engine bay. Furthermore - open cone filters with heat shields also draw in hot air because the shields are not fully sealed and the cone does not directly draw in air from the duct. There is minimal airflow being forced into the duct as it terminates well above the grill.
    The Stock System
    Unlike the small stock airboxes in the RS5, the S5 airbox is a decent size which draws in air from the duct that terminates behind the front grill. The stock filter itself is cylindrical and so has plenty of surface area however the airflow path is not so smooth. Parts of the stock filter are shrouded closely by the airbox and airflow has to negotiate through several turns before ending up at the throttle body. Since the airbox is mounted to the chassis - the inlet tube has to be flexible to allow for engine movement - therefore contains ridges which are also not great for smooth airflow.
    The Eventuri Design
    As we did with the RS5 - the main component in our intake system will be our Patent Pending Eventuri filter housing. This provides a smooth transition from the filter opening to the inlet tube to maintain laminar airflow through the system. Another feature of our venturi design is the increase of gas speeds at the housing exit which allows for better throttle response.
    Here is a diagram explaining how our filter housing is so different to anything else out there:
    The effect this has on a supercharger is a reduction in drag due to the laminar flow which allows the charger to work more efficiently therefore resulting in more power.
    Unlike many "carbon" intakes, we will be using 100% prepreg carbon fibre and plenty of it! Our housing will have a 2mm wall thickness which is unheard of in this industry. This means that the carbon will be a very effective insulator from the high heat of the engine bay.
    The filter housing will connect to a carbon tube which will gradually reduce in diameter from the housing exit to the throttle body - matched at both ends.
    Finally and perhaps the most challenging part is the cold air feed. This will be 2 components, the duct and the scoop. Our duct will connect to the stock duct and then smoothly transition to the circular filter opening of the housing. It will be fully sealed to the stock duct and again sealed to the filter housing. Finally a scoop protruding down from the stock duct behind the grill will force ambient air upwards and into the intake system to ensure low IATs.
    Initial CAD Models
    More updates to follow...........
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Sep 17 2015
    Vancouver, BC
    Badass!
    Veteran Member Three Rings Bikel's Avatar
    Jun 19 2013
    sub'd
    2010 S4 | Prestige | Ibis White | DSG w SD | ADAC Grille Badge
    Feb 10 2012
    B8 S4
    SF|CA
    Whats the expected price point going to be? I was on their website a couple months ago and they had intake systems for a couple thousand dollars!
    I would love to buy their "cone" and strap it to my Roc Euro Intake.
    B8 S4 | Black Optics | 6MT | Sport Diff | Carbon Atlas | APR Stage II | StaSiS Ohlins SL | AWE Touring | Eurocode Stage III Clutch/LWFW | Eurocode ÜSS | Eurocode Alu Kruez | Enlaes Duck tail | Deval F/R carbon diffuser | O Carbon dash surround | Valentine V1
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Hello Eventuri,
    Are scoop extension and carbon scoop compatible with aftermarket cold front big heat exchangers ?
    I worry about those pièces that will interfer with the top of the upgraded s/c hx .
    Thanks in advance,
    Verry interrested! But of course waiting for datas and pricing !!
    Best regards
    Mathieu
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Aug 25 2013
    florida
    Quote Originally Posted by collins4 View Post
    looks like single stacks are going to be close to $900-1000 since their double stacks are $2-$2,500 usd.
    that's a lot of mod money just for an intake. design and weaves on their other intakes look solid though.
    2014 sfeux p+ 6mt bo nav w/o sd
    Oct 13 2009
    MN
    Quote Originally Posted by Oloung1 View Post
    I'll be surprised if its that 'cheap'. They make beautiful intakes, but damn the price is crazy.
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Too much $$, ECS intake and soon to be released 034 are better priced for this market.
    My .02...
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Worst dollar to hp mod ever made, good lord.
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Jun 05 2014
    2010 A4 6MT Prestige 19" Sport
    Philadelphia Area
    ... But what does it sound like?
    Sent from my A0001 using Tapatalk
    2016 S4 6MT SD BlackedOut B&O Tech
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by bmoreS4 View Post
    On par with an exhaust 😂
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Jun 28 2016
    US
    PRM intake system... anyone remember those guys? I do...
    Senior Member Three Rings Low Flyer's Avatar
    Oct 25 2008
    MD
    Seems interesting, if the price point is reasonable, this would be a nice system.
    A fair amount of euros.....
    Nov 10 2014
    Apex, NC
    if the HP is on point or better than the Roc-Euro and it keeps IAT's low it will be worth it, because its definitely a show piece like the ECS .. they also make engine covers, i'm assuming if the intake does well you could get a nice engine covered piece to match the colored carbon intake like the RS5
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    ^Damn that's hot.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Sub'd for more info...
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Very interested in this. I was also curious why no one designed a dual intake for the 3.0. I thought I remember seeing one on a SQ3 that made good power.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by 4Rings3Liters View Post
    because we only have 1 TB
    Present:
    Apr 11 2012
    interested to see if you guys make more power from a closed system, so far with the 3.0T, open has consistently shown the largest gains.
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    Quote Originally Posted by will13k7 View Post
    Their theory is, yes, open element may make more power on a dyno with the hood open and fresh air getting to the element, or on a 1/4 mile track with a cool engine, in real world driving a closed system will remain more reliable with better heat soak prevention. This new system has the promise of increased air flow through multiple inlets, hopefully close to an open air, plus better prolonged heat soak rejection through a closed system.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by jmaddr View Post
    i had the same question as Will http://www.audizine.com/forum/showth...er-development
    but it goes a little more than dyno and 1/4 mile track, people in this forum have actually logged real world driving with the open air design and it showed lower IAT's
    Present:
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Found this online
    Took a screen shot of it! Looks sexy
    Sent from my SM-G900W8 using Tapatalk
    Apr 27 2011
    MD
    I'm sure it will look good, but $1k with no performance increase over a $250 intake, no thanks.
    IG: @s4dad
    Nov 28 2015
    Montreal, QC
    and less sound from it than an open element, i like that sound lol
    S4 B8.5 no track, just enjoying spirited driving.
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    +1,000,000!
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Oct 13 2009
    MN
    I'll reserve judgement until the very least they release pricing and some data. If its under a 1K I'd probably bite. Its a beautiful piece.
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    Quote Originally Posted by doug97gxe View Post
    i checked IAT's with both my p3 gauge and vagcom, here were my observations
    the open air intakes actually idle and hover around the same temp as ambient (usually for me it's 1-2 degrees lower than ambient according to mmi)
    this is the same with the stock intake on the car
    if you say got stuck at a stand still or crawl traffic or went through a drive through for a quick mc donalds, you can see it going past ambient very very slowly ( 1 degree per minute ish)
    the most it ever went was 8-10 degrees past ambient (86 degrees , ambient 76)
    say traffic clears up , i drive at 40 mph constant , within 30 seconds, the temp goes back to ambient
    stock intake did heat soak in traffic also , but it was +6 , never saw any more than that
    also takes same time to get back to ambient
    Jun 14 2015
    FRANCE
    Quote Originally Posted by sirsycott View Post
    Hi,
    Your IAT behavior seems very low compared to what i observed..
    Is it with an aftermaket front end ??
    BR
    Mat
    Senior Member Two Rings Quidproquo's Avatar
    Aug 06 2015
    2013 Audi S4, 2007 Nissan 350Z Enthusiast
    Morris County, NJ
    You can't rely on the P3 gauge... Per conversations with P3 Cars reps... Their gauge currently reads the "ambient temp" NOT the "intake temp".
    They plan on releasing a revised map late in the fall with additional features for more $$$.
    2013 B8.5 S4 DSG (034 Motorsports intake tube | air box mod | aFe Pro Filter | CTS+183mm Iabed Pullies | EPL Dual Pulley 93 Pump Tune | SunTek 35% Tint | 19" S5 Rotor Wheels)
    Apr 11 2012
    this. plus the guys getting the best quarter mile times think open-element worked best for them. would be interesting to see a closed system that shows otherwise. I guess there could also be a system better for the track and a different system that's better for daily driving.
    Sep 20 2006
    MD
    Quote Originally Posted by CrownSeven View Post
    Given their current offerings, I'd say to expect a $1K price tag.
    Apr 26 2005
    Houston
    its a great kit - they sold over 40 units in the rs5 forum and everyone loves it. the dyno numbers were no lie
    • eCode headlights
    • Eventuri intake
    Sep 20 2006
    MD
    Quote Originally Posted by chrissurfr View Post
    For that $2K price tag, it should! If this has an intro price of under $1K (hoping sub $800s but wishful thinking most likely) I maybe game. If the gains on a N/A motor, like the RS5 is roughly 15-20hp, I could imagine the gains to be better on a force induced motor.
    Jun 14 2015
    FRANCE
    Hello,
    Yes, it could be interresting to show some gains, but not only vs. stock airbox/filter, but also vs. a competitor open intake.
    Cheers,
    Mat
    Apr 04 2015
    United States
    Sub'd for proven gains over Open Air Element intakes.
    Apr 26 2005
    Houston
    Update.....
    We will be logging the intake system and stock airbox with VAG-COM to measure IATs and MAF values. The aim is to keep IATs low while increasing the values for airflow volume. We will also do some comparison logging for the IATs between the sealed design we have VS an open design (we will remove the duct which will expose the filter).
    To enable the filter to breath better we have added a second air feed to the duct. This inlet is at the base of the duct to which we will attach an 80mm diameter flexi hose and guide it under the headlamp where the temperatures are ambient. This additional inlet ensures the filter is able to draw ambient air without the restriction of just breathing from the stock duct area.
    Here is a render of the duct design showing the secondary inlet port.
    • eCode headlights
    • Eventuri intake
    Nov 28 2015
    Montreal, QC
    Update.....
    T
    That's not a fair comparaison.. a true open design feature a cone filter and a revised inlet pipe.
    chris, do you work for eventuri ?
    the secondary port is a nice idea. don't think anyone else ever thought of that.
    Jun 14 2015
    FRANCE
    Quote Originally Posted by waxxonMTL View Post
    Hello,
    Are you sure ?? ;o)
    http://www.audizine.com/forum/showth...x-hole-testing
    BR
    Mat
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    $1000 for 3 HP..........
    Sep 20 2006
    MD
    Quote Originally Posted by S4'ed View Post
    Provided the data given on the RS5 application and the fact that forced induction applications typically see bigger gains than N/A applications, I'd say this is good for atleast ~15 AWHP.
