Results 1 to 10 of 10
    Veteran Member Four Rings Tone-Dogg's Avatar
    May 06 2007
    2020 Q3 P+
    Hartford, Connecticut
    Squealing noise, tensioner?
    Hey guys, trying to help my father out with his 2010 B8 a4. Late last night he got this noise at idle. As he turns up the rpm's the noise will go away.
    My first thought was tensioner, then a vacuum leak, and the funny part is, after the car is turned off, it lingers for a split second, leading me to believe it's something other than the tensioner. But my gut tells me that.
    I also tried releasing tension to see if the noise was constant and couldn't get the tensioner loose enough to stop spinning with out risking injury. (Needed a longer extension)
    Any thoughts are most appreciated. Thank you in advance.
    Sent from my SM-N910V using Tapatalk
    2016 Q5 3.0T Quattro P+ Sline Black Optic
    2020 Q3 2.0T Quattro Premium +
    May 06 2007
    2020 Q3 P+
    Btw, CEL is from prior.
    Aug 27 2008
    Houston Area
    Quote Originally Posted by Tone-Dogg View Post
    Is it actually revs or more throttle position?
    When my PCV valve failed in my '09 a4 it sounded somewhat similar, but the noise went away with throttle (less vacuum) I could create the noise by letting off the throttle, and make it go away by adding throttle in the same gear - so very minimal RPM change.
    May 06 2007
    2020 Q3 P+
    No you have to get on it and raise rpm's up to like 3k before it will quiet. He decided to drop it at the shop, oil light came on. Ugh....
    Jun 06 2016
    Woodbridge, VA
    Sounds like you need a crankcase breather valve. The rubber diaphragm inside tears and causes a vacuum leak/lean condition.
    2017 Q5 3.0T - Stage 1 APR
    May 06 2007
    2020 Q3 P+
    Tku sir, will pass along.
    May 06 2007
    2020 Q3 P+
    Quote Originally Posted by dannydc24 View Post
    Winner Winner!!! Thank you so much!
    Mar 26 2014
    Had the exact same thing
    Jan 03 2013
    Baltimore
    By crank case breather do you mean the PCV valve? I just got the same high pitched squeel on my way to work. Goes away between 10hg and atm. Noise is present at idle and in boost. Car runs rough and the rpms in neutral go up to about 1500 and go back down. Pulling the oil plug for the dip stick makes the car run very rough but the sound goes away.
    Bad PCV valve?
    Quote Originally Posted by JVince View Post
    Sent from my Pixel using Tapatalk
    Feb 15 2016
    Cambridge,Ontario
    yup squeeling/ whistling is PCV .
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
