Results 1 to 12 of 12
    Feb 06 2013
    WV
    2.0 vs 1.8, what's the difference?
    I asked this on the b5 section and got no love so I am asking here.it seems this upgrade is done more in the b6 then the b5. I have a 2001 avant and am thinking about this upgrade coupled to a 6758efr or 7163 efr (choices choices, makes it harder it when your sitting on both)and I would really like to know what the gains are, specifically.
    I know it makes more hp at less psi, better spool, etc. How much though or is there a clear cut comparison of the 2?
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Aug 26 2005
    More hp at lower boost with a larger turbo is a myth. Developing the same hp, the boost will be the same for both turbos. The only difference is that the larger turbo will be running at a lower RPM for the same boost.
    Vorsprung durch Technik
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    did you mean the smaller turbo?
    GIAC-X, STASIS TS,VAST,034 MS
    Feb 06 2013
    WV
    ??? I am saying that a bigger engine will require less boost to make the same hp with the same turbo, that's a benefit.
    I was hoping to see a good dyno comparison between the 2 but have yet to find one.
    Aug 26 2005
    No, the larger turbo will be spinning slower at the same boost.
    Feb 06 2013
    WV
    Can you explain? Everything I have read is contradictory to this statement. A larger engines moves more air at a lower RPM then the smaller engine. That in turn increases spool. If you think of a 2 liter bottle being filled by a compressor that same sample of air being stuffed into a 1.8 liter bottle will have a higher psi to hold the same mass of air.
    I am interested in this greatly.
    Senior Member Three Rings thetikm's Avatar
    Jun 24 2014
    NC
    You guys are talking about two completely different things. Diagnosticator is talking about turbo size. You are asking about engine displacement
    Feb 06 2013
    WV
    That's what I thought. He needs to pass that to the rest of us....
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    Depends on what version of the 2.0 you are talking about. The 2.0t in the B7's are Direct Injected, but still shares a lot of similarities to the 1.8t.
    Jun 24 2014
    NC
    Are you talking about a stroker build.
    Feb 06 2013
    WV
    Yes, I am b5 which is strictly 1.8t but I am 06A. I am trying to use my budget the best I can and on the fence of what will get me the best overall results. I am going to use the 6758 efr (though I also have a 7163 efr) and I am thinking 2.0 Stroker over built and cam'd head. I can always upgrade the head later but is the extra displacement going to pay that much dividends with this turbo setup?
    Aug 26 2005
    Quote Originally Posted by thetikm View Post
    Yeah, I misunderstood the comment by the OP, "I know it makes more hp at less psi, better spool, etc.", where guys often incorrectly think a larger turbo makes more power at lower boost.
    The power difference between a 1.8l and a 2.0l displacement engine with all else equal is only a small difference.
    Compared to a 1.8l engine a 2.0l with the same size turbo will spool slightly sooner due to the small increase in exhaust gas flow rate with the 2.0l displacement. Stated another way, compared to a 1.8l displacement engine, a 2.0l engine will develop the same boost at a slightly lower RPM with the same sized turbo.
