Results 1 to 6 of 6
    Mar 10 2014
    Norway
    Remove and replace window regulator rivets - no drill or riveting machine
    Looks like I have to replace the front window regulator and I hear it has rivets. Is there any way to remove them without using a drill, dremel, grinder and can I replace them with some nuts and bolts? If so, what dimensions should the bolts be?
    A4 1.8T Quattro 2000 ANB
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Its very easy to take a center punch and small drill and removes the rivets. Took me 5 minutes. Dont know how else you would remove those rivets.
    Reinstall with new rivets.
    Do it right.
    Mar 10 2014
    Norway
    Is there enough room under the rivet head use a steel saw?
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Quote Originally Posted by todda7 View Post
    buy a fucking drill.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Mar 10 2014
    Norway
    Quote Originally Posted by King_ View Post
    All right ... What about nuts and bolts instead of rivets? I live in a 120 ft2 'apartment' and own enough one-time use A4 tools already
    Oct 09 2012
    A drill isn't a one time use item. There's always more shit to drill. Just pick it up at a pawn shop for cheap. As for the rivet tool it's like 4.99 at harbor freight. Also pick up a center punch at harbor freight
    Sent from my Jailbroken iPhone 6s iOS9.3.3 using Tapashit
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
