Results 1 to 9 of 9
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Drag strip help!! Car bogging like crazy
    So went to the 1/8 mile tonight with some buddies. Currently running 91 map with 6 gallons of 91, 6 gallons of 100, and 3 oz. Of Aces. Track is in the San Diego Chargers stadium parking lot so it is not a prepped track. My first run was great, launched great and car felt pretty good all the way through. (Oblidirated a Camaro), ran a 7.8. I did notice way more traction issues then I have ever felt in my car compared to Fontana raceway and even doing a launch on the street.
    Here is where it all went south, next race, couldn't get car to launch so bogged like crazy off the line. (Ok could be user error I've had it happen before) but runs 3 and 4 the car launches great, (did feel a good amount of wheel spin, crappy track probably) but then my car shifts in to 2nd gear and literally felt like I wasn't getting any fuel or some type of Audi precautionary measure was happening. I would let off the gas and my car would feel fine after giving it gas again but WTF? I felt like a moron out there! Any thoughts?????
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    Quote Originally Posted by Djpeaksd View Post
    Did you hit the rev limiter coming out of first gear and did you ensure all traction control was off?
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Dguth View Post
    Yeah I turned the traction control button off, is there another setting or something? Also yes I hit the rev limiter.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Feb 14 2014
    13 S6, 13 Q5, 72 Chevelle
    Oklahoma City
    Just to be clear, when you say "bog" I take that to mean the rpm's dropped low, like the 2k-3k rpm rang, taking you out of the power band? If that is the case, I would guess it was a DSG "issue" causing the car to short shift into 3rd after the 1-2 shift. But that just a guess
    I don't have a ton of expirrence in my s6 and launching it, only had it for 6 weeks now. But the 6-8 times I launched it prior to the ECU tune it never did anything weird, just hooked and went. But in the 6-8 launches since stg 1 a couple of them have not gone right. I figure it has just been massive wheel spin and the car simply not liking it and short shifting. I don't know that I believe that with "traction control off" it truely disables everything
    Dec 14 2011
    Dublin, OH
    Sometimes if you hit the rev limiter it will bog and cut power. It's happened to me a few times in my S6. Some guys will manually shift out of first to avoid that.
    Feb 01 2016
    Encinitas, CA
    Yeah I used bog, but that isn't the right word for what happened. It felt like it cut power! For some reason I was under the impression that I had to be in manual mode to launch the car so I've always done it that way. My buddy just informed me that I just need to be in Dynamic and trans in sport. So I just launched in automatic and it felt great! So not sure why it would cut power when you hit the rev limiter but???
    I need to get back out there!!!!
    Dec 14 2011
    Dublin, OH
    Yeah, you're right, bog isn't the right word. It actually cuts power in my case when I hit the rev limit. Stumbles, then recovers but it's usually too late at that point.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Does your TCU tune automatically up shift in manual mode? If not it sounds like you were hitting the rev limiter and it was cutting power to protect the engine... Exactly what it's supposed to do.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by gk1 View Post
    It does! That's why I was just letting it shift automatically for me even though I was in manual. But now that I know i don't have to be in manual mode to launch I'll try it that way next time. Hopefully I can get past this issue. I definitely was not banging off the rev limiter as my tune will not allow it.
