Results 1 to 19 of 19
    Established Member Two Rings Harddrive's Avatar
    May 03 2011
    West Africa
    Sealant for Cam Cradle
    Gents, so was attempting the chain and tensioner replacement and got screwed by the dreaded cam adjuster bolt. Mofo stripped out .
    So I'm moving on to plan B: remove the cam cradle and pull out the intake cam. Did lots or research and it seems scraping off the factory sealant is the major drama here.
    And here comes my question. Which sealant should I use aside from the atrociously overpriced oem one.
    I'm currently considering the following two options
    https://www.ecstuning.com/ES517987/
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    00 A4 2.8Q Tip | APR Snub mount | Stern Power Ring | K&N filter. Sold
    06 A4 2.0T Tip | APR Stg 1 | KN Filter | APR Snub mount | Cupra lip | RS4 Rear Sway Bar | AF1 Trunk lip | 034 HFC | OBX Cat Back
    Jun 27 2011
    I used Dirko on mine 3 years ago, and its held up great.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    May 03 2011
    West Africa
    Charles, i saw your comments about it in another post hence why I picked it. Then i came across the copper one and was intrigued by its purported properties and higher temp ratings. Do you think its a better product?
    Though if the Dirko has held up for 3 years, it seems the safer choice.
    Jun 17 2013
    jersey city nj
    Dirko
    May 03 2011
    West Africa
    Cool, Dirko it is.
    One more thing. How long should I let the sealant set before starting the engine after reassembly?
    Jun 17 2013
    jersey city nj
    After I the sealant I the parts back together
    May 03 2011
    West Africa
    Quote Originally Posted by vce1232000 View Post
    So are you saying I can crank the engine immediately after full reassembly? I thought i would have to wait a few hours first.
    Jun 17 2013
    jersey city nj
    I did.... After you the cradle. You have about 30-45 minutes worth of to do anyway before you start up the engine. More then enough time for sealant to do its job. Besides when to tighten the craddle up to the head its pretty seal at that point anyway
    May 03 2011
    West Africa
    Cool. Gotcha!
    Jun 27 2011
    Yea I'd give it an hour minimum. It might specify setup and cure times on the tube. I wouldn't push it, I'd give it the full allotted cure time before starting it up.
    -CP
    2017 Q7 3.0t
    Mar 24 2013
    Oakdale, CT
    Im pretty sure the tube says 24 hrs
    -Adam
    Jun 17 2013
    jersey city nj
    I was never good at following directions
    May 03 2011
    West Africa
    24hrs. Hot damn!
    Well if the tube says so....better safe than sorry.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Harddrive View Post
    24hrs. Hot damn!
    Damn..........Thats what I get for not @ the directions on the tube
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Go to your local honda dealer and pick up a tube of hondabond. Its pretty much the best sealant out there.
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Active Member Two Rings atvhead's Avatar
    Sep 06 2016
    A4
    NH
    I've heard hondabond mentioned on other forums too, with high regard
    Dec 04 2011
    Kansas City, KS
    should only run you about $13 a tube. Its gray magic.
    Feb 15 2016
    Cambridge,Ontario
    On porsche engines that use no gaskets the recommendation is three bond 1104. This has been rebranded as Yamabond 4 and
    Hondabond.
    I used the Yamabond 4 during my air cooled engine rebuild and it worked amazing. Just make sure surfaces are squeaky clean as in brake cleaner then alcohol until clean
    Sep 11 2009
    A4 B7 2.0T MT, A4 B5 1.8 MT
    South Africa
    Hondabond.
    I see there is Hondabond HT and Hondabond 4. Do you know the differences and which one is better?
