Results 1 to 14 of 14
Thread: Boost hose kits
    Established Member Two Rings ildottore46's Avatar
    May 05 2014
    nebraska
    Boost hose kits
    Hi,
    Ive been thinking about buying a set of aftermarket hoses. After searching, i found samco, mishimoto, forge, autobahn88, and the ecs kit.
    Ive found reviews for all of the kits but the ecs kit. Does anybody have any experience with the ecs kit?
    For the price, the ecs kit doesn't look too bad. I also liked that it comes with new clamps. I already have a samco TBB so im not concerned about the ecs kit not including one.
    https://www.ecstuning.com/News/Audi_...002/ES2800108/
    Thanks,
    Nick
    Nick
    Established Member Two Rings BOO$TedS4's Avatar
    Oct 06 2015
    96 jeep Cherokee sport, 95 Mitsubishi Eclipse GSX
    Williston ND
    Also been thinking about it
    Aug 24 2014
    Newport Beach, CA
    I used the 034 kit personally, but a few of the hoses did not fit well at all. Most of them fit ok.
    2024 M3 Comp xDrive
    May 05 2014
    nebraska
    Quote Originally Posted by christianb5s4 View Post
    I was looking at 034 too, thats one thing i keep seeing, A few hoses are a pain to get to fit properly.
    I have the 034 spider hose and liked how it fit. Was kinda bummed to see the boost hoses from them aren't as easy to fit
    Nick
    May 05 2014
    nebraska
    Bump
    Any reviews or info on the ecs boost hoses? Curious to see how they hold up.
    Nick
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    the autobhan88 hoses arent that bad surprisingly actually. Only one that fits poorly is the weirdly shaped driver side hose right after the turbo.
    May 05 2014
    nebraska
    Boost hose kits
    @rguil when u got your hoses, were they clean on the inside? Most reviews ive seen have said that there is a lot of excess material on inside of the hoses. Also, they need a lot of trimming. Are you using all of the hoses are just a few?
    Nick
    Dec 17 2014
    San Diego CA
    Quote Originally Posted by ildottore46 View Post
    I dont know if they were clean on the inside new, they came on the car and have held up great for two years since ive had it, i used to use them all but all i use now is the lower hoses to my FMIC and they are holding 30psi no sweat.
    I liked the lobster claws the most and was able to fit them over srm inlets but i stopped using those too when i deleted my maf and y pipe lol.
    Aug 06 2008
    Canadia
    Quote Originally Posted by rguil View Post
    This, but lobster claws didnt fit great for me.
    Been on the car 8 years with stock clamps and working fine, no tears leaks, etc (im not sure what could fail on a piece of silicone hose TBH)
    the B5 S4 is like the mafia... there is only one way out!
    Jun 06 2010
    germany
    I have the Samco... fit perfect good quality.
    May 08 2016
    Manhattan
    Bump
    I have this kit on my car for a little more than a year quality is pretty good for the price no problems so far.
    May 05 2014
    nebraska
    That's good to hear, im most likely going to buy them Monday.
    Nick
    May 16 2008
    WA
    Same, just wrapped up installing a set for a friend. That driver turbo outlet hose needed a bit of trimming to suck it up to avoid rubbing on other parts but other than that it was pretty good. I cant comment on all the hoses as we also installed SRM SMIC at the same time, and those come with some of their own hoses.
    Senior Member Three Rings Bob Marley's Avatar
    Jan 18 2016
    Queens NY
    Just purchased the full ECS kit which surprisingly included a new TBB & "F" hose...I've heard other versions of the Kit doesn't include... Haven't installed yet as I'm waiting on other parts while the motor is out. But from the looks it seems like a very well made kit. I also will be going with RS4 intercoolers which have they're own hoses...so at least 4 hoses won't be used. If there's any issue with fitment I'll be sure to update.
