Results 1 to 25 of 25
    Active Member Two Rings dark_m00t's Avatar
    Sep 04 2016
    kansas city
    boost gauge reading 0
    I installed a new boost gauge this morning and at idle it reads -14. When I put the pedal to the metal it just goes to 0-1 and never more. The car feels fast and isn't throwing a code so whats going on? Every thread I read about this was not helpful..
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Did you install just a vac gauge? Lol
    Dumb suggestion but I've seen weirder shit before.
    2016 S3
    Instagram- @Thisisastickup
    Sep 04 2016
    kansas city
    this right here https://www.ecstuning.com/Audi-B5_A4....8T/ES3047925/ I put the T fitting into that tiny line running into the very front of the valve cover.
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Quote Originally Posted by dark_m00t View Post
    Valve cover or intake manifold??
    Sep 04 2016
    kansas city
    Quote Originally Posted by Rodgman15 View Post
    Oh my god face palm I mean the intake manifold of course..
    Jan 12 2014
    Fargo, ND
    Lol ok had to be sure. I never got full accurate vacuum readings from there, I'm T'd into the fuel pressure regulator.
    Sep 04 2016
    kansas city
    I might try that but surely it would not just be 0 even if it was wrong?
    Jan 12 2014
    Fargo, ND
    Have you done a boost leak test?
    Sep 04 2016
    kansas city
    yes, no leaks that i can hear or see..
    Established Member Two Rings nota_towel's Avatar
    Jul 26 2013
    central mn
    There is most likely a small leak some where in the vac line or maybe the line you installed is pinched somewhere. Check all those little piece of shit hoses that connect to the valve cover and diverter valve. Also a possibility that the electrical sending unit is bad, I've never liked digital gauges and usually opt for traditional ones.
    FYI my usual readings with that tune are -19 vac and like 18psi for boost
    Sep 04 2016
    kansas city
    I just checked the line from the DV up to the T and yeah it split. New lines, a new T and now the gauge reads -10 at idle and still 0 on "boost". Would it matter that I haven't installed my forge splitter yet?
    Jul 26 2013
    central mn
    Possibly if your dv is wrecked, tho I'm not fully sure
    Sep 04 2016
    kansas city
    kms
    Jul 26 2013
    central mn
    Any check valves between your vac line and where you spliced the gauge in?
    Sep 04 2016
    kansas city
    I'm going to guess that the stock DV is broken. Am I correct in thinking that A broken DV will just let all the pressure out into the air and ill be running rich with no power? My gas mileage was pretty terrible today.
    Jul 26 2013
    central mn
    Yes the valve regulates the pressure, and if it's broken wouldn't let any boost build up. Try swapping out the valve ASAP and see how that effects it
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    You have a boost leak somewhere. Pressurize the intake side and let us know. Google "b5 a4 boost leak test" for DIY.
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Sep 04 2016
    kansas city
    RIP i think i just found the issue. After I installed the forge splitter, during the test drive my cat just blew off the flange to the turbo.
    Sep 04 2016
    kansas city
    - - - Updated - - -
    Quote Originally Posted by AudiSport12 View Post
    I did this yesterday and everything seemed alright.
    Am i supposed to be able to move the waste gate actuator with my fingers? I can move it open and closed when the car is off with just one finger on it.
    edit: yeah i can move the flapper completely open and closed with barely any force at all. i thought there was supposed to be spring tension? am i retarded?
    Jul 26 2013
    central mn
    I think that you probably have a bad waste gate. That would explain the boost gauge reading 0. If the waste gate failed and is stuck open you won't be able to build any boost
    Sep 04 2016
    kansas city
    Quote Originally Posted by nota_towel View Post
    bummer. is this a genuine setup? the kkk plate is missing. http://www.ebay.com/itm/Audi-A4-A6-V...FW09Tb&vxp=mtr
    Jul 26 2013
    central mn
    I have an old k03 that I thought was bad but is in decent shape. A little front to back shaft play but if you need it for the waste gate it would be good. I really only want $30 for it
    Sep 04 2016
    kansas city
    sold. how much for epic super shipping?
    Jul 26 2013
    central mn
    Dunno I'll try to find something that will be quick tomorrow
    Sep 04 2016
    kansas city
    cool thanks!
