Results 1 to 14 of 14
Thread: 275/40R20
    Sep 05 2016
    Ottawa, Canada
    275/40R20
    Folks, can anyone confirm that 275/40R 20 will fit without rubbing on a 2017 Q5 on stock 20 inch rims ( peelers) and stock suspension. I have the opportunity to get this size winter tires and want to make sure they fit. Also, is it recommended to run that size since they are almost 1/2 inch shorter and 3/4 inch wider?
    Envoyé de mon E6653 en utilisant Tapatalk
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    They won't rub but that size is also probably too wide for stock 20" wheels. Those are 8.5" wheels and most 275/40R20 tires are specd for 9"+ wide wheels.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    And trust me, you don't want to riding on 275 series winter tires. You'll just float on top of the snow rather than cut down through it. You want a narrow tire. I'm running 235/55R19 on 19x8.5". If you want to run 20", you stuck with stock size of 255/45R20.
    Sep 05 2016
    Ottawa, Canada
    I'll take that advice, thank you. Good point on the floating on snow comment.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    It's true that you'll want skinnier tires for snow, but they'll fit just fine. The 20"s have more sidewall than larger wheels, so there is more flexibility.
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    What about 275/45/20's ? Seem like that should fit still minimum rim width is 8.5. diameter is .7 or .8" larger. I just measured roughly 12mm from my tire to the knuckle.
    This got me thinking -295-s-are-on!-Pics
    Steve
    '15 SQ Monsoon
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    I run 265/40/20 with out any issues. Waiting to be spaced out...
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    Might even smooth out the ride a bit with a bit more rubber
    Steve
    '15 SQ Monsoon
    Jul 10 2014
    Quote Originally Posted by Jimminez View Post
    Dammit lol... I got the wide DWS FOR the snow/winter! Figured I'd run them year round on the SQ
    Sep 28 2010
    NW NC / DE
    I bought 295 for snow lol. I've done 285 and 295 plenty of times. And Martin is correct. They will not cut well, and you'll get pushed around more.
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    We don't see snow here barely ever and I have a different rig for Tahoe trips.
    Steve
    '15 SQ Monsoon
    Sep 17 2007
    Quote Originally Posted by Silverarrow240 View Post
    I will say, I had to drive in the middle of the small snowstorm that we had here in the tri-state with the 295 DWS and it did pretty well.
    Jul 10 2014
    Should be better for drifting then!
    Jan 09 2009
    1of50
    I also drove in the tri state snow storm and although the 295 managed, I did feel them slip and slide when going around 2 roundabouts. 295 DWS are good but not great. I've always ran snow tires and wanted to give AS a try for this winter but now I'm looking to pick up snow tires.
