Results 1 to 6 of 6
    Jul 15 2014
    Cape Breton Island
    235/35 R19 tires weight loading
    So I blew out a sidewall on a PSS (235/35 R19) on 8.5" rim.
    No big deal right?
    I called up discount tire to get a new one and they asked me what vehicle it was going on, and I told them.
    "Sir your car is to heavy for the 235/35 combo would a 255/35 work?"
    I said nope and suggested to try a different brand name.
    No luck there, they said all the 235/35 R19 in any brand do not have the adequit load rating for your vehicle.
    So this leaves me.... Did the sidewall blow out because my tires weren't the proper load rating for my car? I thought there was lots of guys running the same set up. The tires have only a few months on them which concerns me on the sidewall blow out.
    May 18 2012
    2005 S4
    Portland, OR
    What load rating do your current tires have? On Tire Rack, there are plenty of 235/35R19 Michelin PSS tires with 91 load rating, which is plenty for any S4 full of people and luggage.
    Established Member Two Rings scorpioS4's Avatar
    Mar 31 2011
    New Jersey/Delaware,Dover AFB
    I was previously running on Hankook v12 235/35 r19 on a 8.5 rim w/91y. I learned the hard way that I had the wrong tires. in less than a year I had chewed through them even with a the proper alignment and lowered. I have since moved up to a 245/35 r19 93y same tire and have never had a problem.. I do rub on occasion when I hit a nice dip, especially in the rear with passengers. normal tire wear with regular rotations.
    2k5.5 Moro blue S4 6spd: k&n drop in/FI x-pipe cat back non res/Piggie DP's/JHM 93 octane Tune w-LA/Intake man. spacers/lightweight crankpully/JHM shifter Trio/JHM stage4 lwfw&clutch/Elbow Heater Bypass Kit/Led strip inlays & taillights (fly's V4's)/6000K D1S and 3000K HID Fogs /Cupra R lip/R.
    May 18 2012
    2005 S4
    Portland, OR
    I mean the closer you get to the weight limit of the tire the faster you will wear it out, but they shouldn't be blowing out sidewalls.
    Deactivated Four Rings
    Jun 23 2011
    I just checked my B7A4 Avant and the minimum load rating is 94. I used to run through tires and finally made sure I had an XL rating 97 or higher and no more issues, but yes 91 or even 93 is less than the min. I assume an S4 will be the same or higher than an A4.
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Quote Originally Posted by Dolphin S4 View Post
    No big deal right?
    Ive been running PSS 235/35/19 now for 3 years. NO BLOWOUTS and i live in NYC. Some of the shittiest roads i've ever seen and driven on. Numerous times ive hit a pothole and assumed my tire was gone. Nope the Michelins held up. Yes technically the load rating is 91, and i do believe that i wear them out a bit quicker, but i havent had a blowout yet.
    and btw i run them on a 9 inch wheel.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
