Results 1 to 6 of 6
    Jan 15 2016
    Suwanee GA
    Question about Transmission Range Sensor and TCU
    So I bought a used 2007 A4 Cabrio a few months back. A couple weeks ago, the CEL came on and the gear indicator panel flashes sometimes but other than that the car drives fine. I bought an ODBII reader and the code was P0706...transmission range sensor. I cleared the code then drove the car and the CEL came back on within the hour. After doing a ton of research on the interwebs, I thought I was dealing with a situation where one of two parts could be causing the problem:
    1. TRS - which from my understanding is a part attached to the side of the transmission housing with a cable connected to it
    2. TCU - which from my understanding is a significantly more expensive part located under the carpet inside the vehicle
    I read that these parts are dealer only so I called my local Audi dealer to get prices for them. The parts guy told me that unless the vehicle is a Quattro, the TRS is incorporated into the TCU and that the TCU would have to be replaced as a whole.
    I've had occurrences in the past with my motorbikes where the guys on my forums knew a lot more about the hardware than the guys at the parts counter. Not sure if that's the case here, but just wanted to get a reality check and see if the TRS and the TCU really are a single piece and therefore I need to replace the TCU (at a whopping cost of $1400).
    Thanks in advance.
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    The TCM is in fact inside the Transmission. As for if the TRS and TCU are a single piece, that I'm not sure of. Also a used transmission is a much cheaper option....
    Edited.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Feb 24 2004
    Minneapolis
    When you say TCU, I assume you mean the brains of the tranny. Mr. Bentley calls it the TCM and says it's under the ECM at the bottom of the windshield.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Feb 06 2009
    328d, Tacoma
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Feb 24 2004
    Minneapolis
    ^^^that thread is talking about the CVT trans. And Bentley says that TCM is inside the rear cover of the trans^^^ Are we talking about a 5 spd auto trans here?
    Feb 06 2009
    328d, Tacoma
    Quote Originally Posted by mtroxel View Post
    My bad, I was thinking about the TCM, not the TCU.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
