Results 1 to 40 of 59
    Veteran Member Three Rings VeNoMS4's Avatar
    Feb 02 2016
    Peoria, Arizona
    Exclamation B8 Oil consumption
    I understand a lot of people have posted about this before but i had a thought.
    So my scenario: It's been roughly 4500-4700 since my oil change, the oil light comes on and tells me to add another quart. So i added a qt of castrol 5w40 oil and everything is good. fast forward, ~3 weeks and ~750 miles later, the light comes on again. I initially thought something must be wrong but then thinking about it, i am close to another oil change.
    So question is, does the oil consume faster as the oil gets used, as in, as you get closer to your routine oil change time frame? What are your thoughts.
    2011 S4 -Ibis White // GIAC Stage I // GIAC DSG tune // AWE Track Cat back // Injen SP Intake // VMR V710 19x9.5 //
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by VeNoMS4 View Post
    How many miles on yours? I didn't even know s4 had that issue. I thought it was with the b8 a4.
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by mintytoo View Post
    im at about 59k miles.
    Jun 28 2016
    US
    I've always had a similar issue to this. I use Mobil 1 and think it's just the damn oil or something. I used it in my previous car and had the same issue. I had the PCV changed in this car and it's still doing it. It's bullshit and it seems to eat more of the oil as the oil gets older and older. I change mine every 10k and just keep an eye on it almost weekly via the MMI and whenever I have the hood open I'll check the stick... it's just become a normal thing to do, like in my previous car.
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by SwankP3RF3ct10n View Post
    What year is yours? Miles?
    Jun 28 2016
    US
    2010 and like 70-something k on it. It's done it ever since I've had it and it, so I don't think I've gotten away with thousands and thousands of miles and bad rings, etc. I honestly think it's just the oil, but don't feel like changing to Castrol German (since it's impossible to find now) or something else to test since I trust Mobil 1 pretty well.
    750 miles for a quart is a little excessive. I go though quart about every 2-2.5k miles. Which is under the tolerance level though Audi. I think Audi has a restrictor fitting for the PVC system to control oil consumption.
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    When did this eating oil issue start for your car?
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by derek.kritz View Post
    yea 750 is absurd but is there any correlation to the fact that im pretty close to an oil change? Could that be the reason? The first time the oil light came on after the last oil change is after 4k miles.
    I mean how long before the motor burns more oil after you added a qt to used up oil?
    at this point am going to get the oil changed and keep track of this.
    Oct 07 2014
    Mount Prospect, IL
    I have a 2013 with 38K on it. I have to put in 1 quart every 4,500-5,000 miles. Never any more, and never any less. Its been consistent
    Junior Member Two Rings windowguy's Avatar
    Jan 08 2015
    I had an oil consumption issues on my 2012 when I bought it used back in 2014. I took it to the dealer and they changed the PCV valve and the oil consumption stopped.
    I would start with a PCV valve change. Not an easy job as the super charger needs to come off. If oil consumption continues then you have an issue with the the rings or the valves.
    Rob.
    Sent from my SM-N920W8 using Tapatalk
    Jun 11 2014
    Pittsburgh
    I've noticed some oil consumption, and the MMI and dipstick don't always match. 2010 car stage 2 tuned
    60,191 - full oil change using Audi OEM filter and Mobil 1 european formula
    62,170 - mmi low oil - added 700ml
    63,840 - mmi low oil - added 300ml
    64,683 - mmi low oil - added 600ml
    so in 4,500 miles, i've had to add a quart and a half, getting progressively worse as the oil gets older.
    1552
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Where are you located? We have it at Walmart here :shrug:
    But yeah, might be time to look into your PCV setup OP.
    Jun 28 2016
    US
    Quote Originally Posted by AMG ROFL View Post
    No, you don't. I can almost guarantee you that because they stopped making it for the US a few years ago. When I say German Castrol, I mean "the green stuff". Yes, the oil was actually a dark green color. The Castrol they have now that's listed as Euro formula or whatever, even though it says Made in Germany on it, isn't the same from what I've seen. There is one 5w40 Made in Germany Castrol I've seen the local AutoZone carry, but I don't believe that's the old green stuff either. Seems as of the past few years, most of these companies have changed their shit so much nobody knows what's good anymore. I truly believe that Mobil 1 is just too thin and the more it remains in use, the more of it just burns off. I contemplated going back to 5k oil changes, but even then, after 3k I still had to add a little bit of oil and the analysis I did for the 10k changes came back fine, so whatever.
    Dec 01 2013
    '93 RX-7
    San Francisco
    Quote Originally Posted by windowguy View Post
    Rob.
    I have a 2012 and it had this issue right when I bought it from a guy, but then it stopped after the first oil change. I also had the PCV valve replaced which may have helped. I used to use the Mobil 1 0W40 but lately I've been using Castrol and Motul 5W40 instead and have been tracking the car quite a bit and haven't had any problems.
    2012 S4 MT6 | Prestige | Sports Diff | Phantom Black Pearl | Black Optic Package | Titanium Package | H & R sport Sways | CR-15 | CTS Intake | EPL Stage 1 | 034 Track Spec Upper Control arms | 034 drivetrain/trans inserts | JHM Shifter
    Nov 12 2015
    Here
    FWIW, at ~50k and oil has only been changed by a dealer at recommended (10k) intervals. Have never seen the level get below halfway between Min and Max (on the display) and never had any Low warnings. Nice change from my old B7 RS4. She was sucking down a liter every 500 miles at the end...
    Mein ist grau
    Feb 02 2016
    Peoria, Arizona
    so if the PCV valve is the issue, the part seems inexpensive so labor is going to be the one to rape me since the SC needs to come off? damn
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I would also be very suspicious of the PVC valve. If you get it done, I would have an indy garage do it. PLUS, while you have the SC off, change the T stat as well. My car, that I bought used with 48k miles, also consumes some oil. I do have an extended warranty but don't really want to go through an Oil consumption test . So actually hoping for the T stat to fail and then have the PVC valve done with the SC off.
    Jul 14 2013
    British Columbia, Canada
    It should only take one hour to remove the supercharger, so hopefully not too much in regard to replacing the PCV.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by Dr GP View Post
    why the thermostat? i understand its component that fails often in this car. When they change, do they change it to something so that it doesnt fail anymore? like the water pump from plastic to Al?
    Jun 28 2016
    US
    Do yourself a favor and change it. It gets changed to a newer revision, but some believe it's no more stout than the original. The problem is the thermostat in these cars is plastic and over time it's believe that it becomes brittle from the temp fluctuations and liquid it's constantly surrounded by. That said, it's almost idiotic not to change it if you're already in there. It's just a few more screws to take off and replace. Both PCV and thermostat require the removal of the supercharger and if you're not doing the work yourself, it's stupid to have to pay twice for it. My thermostat failed and I had the PCV changed... didn't do shit for the oil consumption issue, but it was something that needed to be done, so while you're in, do it. Now, if you're doing the work yourself, then that's your call, since it doesn't cost you any money, just time if you had to do both things separately.
    Feb 02 2016
    Peoria, Arizona
    Thanks for the tip. I'll definitely do it then
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    if I'm not mistaken I remember reading about a TSB regarding the PCV valve and the premature failure of it. It wasn't an issue right across the board but if you experience issues of oil consumption where more than 1quart of oil was required between service intervals then they would take a look (ie replace the PCV).
    When I first bough my car with 22K kms on it, I needed a quart in between service intervals (15K kms) for the first 2 services. However now the last 2 I haven't needed to add oil and I see very minimal consumption. I'm at 70K kms now.
    Very odd indeed since the dealer has always been doing the changes via Audicare. Only difference I can think of is now that I have a garage to park in where as before I was always outside.
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Jun 28 2016
    US
    That TSB also called for a new ECU flash if I'm not mistake, so I'm wondering if something was different in that ECU flash that made more of a difference than the PCV swap itself. I know when I had mine swapped, it was at the time I did the thermostat, so not part of the oil consumption TSB and hence the tech wouldn't have followed that... maybe that's the difference or something. Who knows... too lazy to dig up the TSB to verify the flash thing, but I vaguely remember something along those lines.
    Found it... apparently the issue requiring an ECM update was in conjunction to actual DTCs, which I don't have.
    Here is an interesting TSB:
    Vehicle: 2011 Audi S4
    NHTSA ID Number: 10051502
    Nature of Defect: ELECTRICAL SYSTEM: SOFTWARE
    Bulletin Number: TSB-01-12-58
    Bulletin Date: Nov 2012
    SUMMARY: AUDI: WHILE DRIVING, MAINLY SHORT DISTANCE (STOP AND GO), HIGH CRANKCASE PRESSURE CAN LEAD TO DTCS P113700 AND P113900 CODES. CRANKCASE PRESSURE CAN BE LOWERED WITH NEW ECM (ENGINE CONTROL MODULE) SOFTWARE LEVEL AFTER CHANGING CRANKCASE PRESSURE VALVE TO IMPROVE AND ELIMINATE MENTIONED DTC CODES. MODELS 2010-2012 S4, S5, 2009-2011 A6 (C6), 2011-2012 Q7, 2012 A6, A7. *PE
    Vehicle Make Model Model Year(s)
    AUDI A6 2009-2012
    AUDI A7 2012
    AUDI C6 2009-2012
    AUDI Q7 2011-2012
    AUDI S4 2010-2012
    AUDI S5 2010-2012
    May 12 2008
    Actually yeah you're right, my mistake. It was the Belgian Castrol 0-40 that according to BTOG's site is as good as GC, if not better. You're right, my mistake.
    Feb 02 2016
    Peoria, Arizona
    dumb question.. but when there is a TSB on your car and your car is out of warranty, will the dealership still fix it since, you know, its a manufacturer defect? or are they going to charge?
    Sep 12 2011
    2003 RS6 Daytona
    Syracuse NY
    Hey y'all, finally a thread I can relate too.
    2010 S4, I burn one quart of oil every 190 miles.. Yeah, a 5 quart jug of oil in my trunk lasts me one thousand miles..
    Already replaced the PCV valve. Doing a leak down test in a couple weeks, and most likely replacing the piston rings. 180k miles and running well
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by EddieK12 View Post
    you have 180k miles!!!??? is this like some kind of record!?
    Jun 06 2016
    Florida
    OP - when the light came on the second time, were you able to visually check the level oil level (with a dipstick), or are you relying on the light? I remember someone here having a similar issue.....he added oil and ended up going way over capacity. Turns out that there was a fault with the light/sensor and he was adding oil to a full pan.
    2018 Daytona Gray S6 | S Sport | Black Optic | Carbon Atlas |
    2011 Phantom Black S4 | S-Tronic | P+ | Nav | Sports Differential | Titanium Package | Silk Nappa | SOLD
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by Dirt View Post
    I wasn't.. I just bought the dipstick for this very reason. I did put some oil in to get the light to go away
    Jun 06 2016
    Florida
    Well damn. On the bright side, you've eliminated at least one root cause. Lol
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    I'm at about 3/4 oil level on MMI after 1335 miles on this oil... (3k intervals these days. 70k on the clock). Back when I used it as a dd (and it was stock). I'd add one quart during every 7k interval...
    May 12 2008
    You sure you're not driving a 335? Lol
    Sep 12 2011
    2003 RS6 Daytona
    Syracuse NY
    Not sure, I'm sure it's one of the more higher miles around though! Never really posted on the forums often, original engine, transmission and clutch
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Sure, they'll fix it, but they'll charge you for it. A TSB isn't a recall. It's basically just resolution steps that the manufacturer suggests the dealer to follow to solve a known problem.
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by jsh139 View Post
    Ah.. Just as I expected. Thanks
    Established Member Two Rings j1n's Avatar
    Aug 21 2015
    Virginia
    The only time a dealer will do work for free on your car that's out of warranty is if its a manufacture defect that has to do with the safety of the vehicle.
    Nov 12 2015
    Here
    Mein ist grau
    Senior Member Two Rings Wreckm's Avatar
    Oct 30 2013
    San Gabriel California
    73k Miles did my oil change at 66k light came on and added a quart at 70k
    I have been adding 1 quart in between oil changes but i am trying to change every 5k
    Jun 06 2016
    Florida
    Quote Originally Posted by j1n View Post
    Or if a new issue was caused by a recent dealership repair. I had a bad injector o-ring that was leaking a tiny bit of fuel.....apparently my car had some work done to the fuel system previously and my local Audi dealer covered the o-ring fix.
