Originally Posted by
krewbrew
A tune will improve torque and horsepower at low rpms (2,000 +/-), but it is still a turbo car and will have some lag. APR has good graphs that show this, although other tunes will be more aggressive and provide more benefit. I believe it will improve lag more than a HFC on a stock car. This assumes your car is working properly (no boost leaks or other issues).
Thanks for the input... I recently did the "throttle position reset" so I'm trying to adapt it to not have so much delay, it really seems like a throttle thing to start with, not regular turbo lag. The car did receive lots of the TSB updates for intake flap motor, PCV/breather tube, coils, "fuel pressure sender" (LPFP?) in its first 50k and ECU flashes early on.. What scares me is at 80k it got an "engine assembly", Camshaft remove and reinstall, HPFP, and lock carrier (cam follower?) loosen/fasten, sounds like a complete cam follower failure, I wonder what the "engine assembly" is, if it's a whole new motor due to cam follower failure? In any case, the engine seems very healthy, idles and runs smooth, just the total granny "floor it and wait" that bugs the crap out of me... I figure if the HFC can be done for less than a tune it would at least reduce lag and be more responsive to start with.
- - - Updated - - -
kil_ling
Well I have a 034 hfc for sale if current interest doesn't fall thru, just saying. Check out classifieds.
I def felt (felt) a difference with the hfc and no tune. Butt feelings and it was noticeable for that matter. Just saying again. Lol
I'll check out your ad, and thanks for the direct input on having HFC with no tune, it sounds like it at least helps responsiveness for sure.
