Results 1 to 19 of 19
    Aug 14 2015
    Spain
    Bad issue with Unitronic Stage 1+
    Hello everyone
    First apologize for my bad English (I'm from Spain)
    I explain my problem to see if someone has passed him.
    I have an Audi S3 have a 8v with 8000km (6300km when installed the Stage 1+). The car has always worked with 98 octane petrol.
    I bought Unitronic 1+ stage through a distributor in Saudi Arabia, since in Spain there are not Unitronic dealer.
    After a problem with the cable, after 2 weeks John solved, I installed the Stage 1+.
    From the first day I noticed the car pulls like stock, I decided to wait a few kilometers to see if the ecu has an adjustment.
    After 1 week, I made some logs the car (i don’t know many parameters) had in 4th gear and see 790 kg / h - 220 g / s, search for internet it was little, I asked John and dealer for the correct blocks to log. He said he would send me a template with the logs they were.
    I received the file and when I loaded it, I saw no use for the car. (I put photo).
    In the end I decided to put the car on a dyno, this is the result:
    The dyno shows me what i feel about the car... i don't feel the 79hp+ what anounced unitronic in his web.
    in 2000-5000 the car doesn't feel the more power and 5000-6500rpm the car not pulls nothing.....
    The thechnician of the dyno says if the temp was low at 20°c the car pulls +20cv.... total 330cv.
    The resulst are:
    265 whp@5400rpm
    312 hp@5400rpm
    443 nm@3400rpm
    John email:
    I don't have any reason to believe that our performance software is not working OK. Our Authorized Dealer that you purchased the cable from can assist you on this, if you'd like somebody to confirm.
    John@Unitronic and dealer not assist me.
    results:
    - 930$ (stage 1+ uniconnect cable)
    - 200$ dyno
    - +700km of test
    - lossen time
    - A car with 300hp (stock 300hp)
    Thank you very much
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    You lose 15-20% HP in drivetrain loss on the dyno. So, the stock 300 = about 240-250 whp. So, probably gained about 50 HP to the wheels.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Aug 14 2015
    Spain
    Quote Originally Posted by Baggio View Post
    Sorry. But don't understand what you say
    Sep 14 2006
    Looks like the dyno he had his car on shows 265 whp, so a gain of 15 whp? Dyno's are so variable, but I think with a stage 1.5 the gains should be a lot higher than that. Also, the OP isn't feeling anything on the butt dyno which is unusual. Honestly, it doesn't sound like his car was successfully tuned.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    only real way to see the hp/tq gains, is if you did a dyno while stock and then another dyno (on the same dyno) after the new software was installed. does your car exceed the factory redline limit?
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Aug 28 2013
    I read that wrong. I thought the 312 number was his whp.
    Aug 14 2015
    Spain
    Quote Originally Posted by diztek View Post
    Several months ago test 80-200 km / h with a friend s3. the two cars push the same.
    Later he purchase an Rs3
    Established Member Two Rings Moha's Avatar
    Mar 29 2015
    Kuwait
    My car felt significantly faster with a JB1 piggyback and also much faster when I upgraded to APR stage 2.
    Stock car made: 259whp
    JB1: 292whp
    APR stage 2: 314whp
    All tuned runs were at 40C temps.
    Tune back to stock and dyno to get an answer
    2016 S3 DSG
    IPE Catback - Bullet Catless DP - APR intake - APR stage 2 tune - Unitronic IC - H&R sport springs - Spulen spacers
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Esto esta raro.
    Es como si no estuviese activo el flash.
    Mi cable esta en camino, pero e montado en el carro de un amigo con el stage 1.5 y la diferencia a la potencia de fabrica es bestial. Se nota mucho y de inmediato despues de el flash.
    Se sentia igual de rapido que mi carro con APR para 98oc de alto torque.
    Voy a hacer unos logs a ver como se comparan con los tuyos.
    As podido hablar directamente con Unitronics ?
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Aug 14 2015
    Spain
    Quote Originally Posted by Slo.Mo.Shun. View Post
    Esto esta raro.
    Hola
    He hablado y me han dicho que haga unos logs con los parametros que dicen.
    Te agradeceria si pudieras hacer logs para compararlos con los tuyos.
    Muchas gracias
    Aug 08 2016
    Oh come on what did he say lol
    Nov 02 2014
    2016 Audi Q3, 2015 Audi S3, 2015 Lexus RC F, 2015 GMC Yukon XL Denali, 2010 Camaro SS
    Quote Originally Posted by Bolet View Post
    Hola
    Muchas gracias
    Hello
    I have spoken and they have told me to do some logs with the parameters they say.
    I'd appreciate if you could make logs to compare with yours.
    Thank you very much
    - - - Updated - - -
    Esto esta raro.
    This is rare.
    It is as if the flash was not active.
    My cable is on the way, but mounted on the carriage and a friend with stage 1.5 and the difference to the power of factory is bestial. It is very noticeable and immediately after the flash.
    It felt just as fast as my car with 98oc APR for high torque.
    I'll do some logs to see how they compare with yours.
    As able to speak directly with Unitronics?
    - - - Updated - - -
    Quote Originally Posted by AnthonyA3 View Post
    hope that helps... :-)
    Aug 08 2016
    Haha ya thanks man
    Aug 14 2015
    Spain
    Quote Originally Posted by afdavey View Post
    Hello
    Thank you very much
    - - - Updated - - -
    This is rare.
    - - - Updated - - -
    Thank you
    Stage 2 Banner Advertiser Four Rings John@Unitronic's Avatar
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    I'm sorry to hear of the situation that you're encountering. I've been working with the Authorized Dealer from Bahrain that you purchased our Performance Software/cable from, but it seems that some of the information (preselection files, etc.) that were sent to you were for another ECU ID/type, which resulted in the incorrect channels to be logged. We've corresponded with the Authorized Dealer and provided channel information to him, but I've sent you an email directly, so you have this data as well now. I'd be happy to assist you, to ensure your complete satisfaction, however, please ensure that we have data needed to help most effectively, as quickly as possible to ensure an expedited resolution.
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Oct 14 2006
    MK6 Jetta
    South,FL
    Acabo de ver el primero de mis logs y parece que tu turbo no esta levantando suficiente presión.
    Tus resultados tienen un máximo de alrededor de 2.6 bar en el campo G077, y mi carro me dio 2.5 bar en el campo G077.
    Mi carro esta con la programación original de fabrica. Y le esto programando el stage 1.5+ mientras tipeo.
    Trate de de grabar los mismos parámetros, pero por alguna razón no vinieron todos iguales.
    Sorry for the Spanish replies guys.
    From the log I just did before flashing my car, it seems that his car and mine are boosting around the same number.
    2.5 bar and 2.6 bar on measuring block G077.
    My car was stock for the logs and being flashed Uni stage 1.5+ as I type.
    I tried logging the same blocks, but for some reason they don't look the same.
    Logs:https://docs.google.com/spreadsheets...ub?output=xlsx
    -EI AL CAI.
    -Driver Mod.
    Aug 14 2015
    Spain
    Hi guys
    After few logs and emails john send me the new files for test.
    I flash stage 1+ file and test it. The car now feels great more low and high rpm power. Now i feel the power. The car was change as the night and day now i think the power is ok.
    Thank you for listen to me
    Oct 14 2006
    MK6 Jetta
    South,FL
    Great to hear
