Results 1 to 12 of 12
Thread: Coilover help
    Mar 27 2016
    Scandinavia
    Coilover help
    Have I put the spring upside down on the damper?
    Instructions are very unclear and doesn't explain this process but I just assume that this is the correct way.
    Reason why i'm wondering is because the upper control arm nut gets very close to the spring
    http://imgur.com/a/TlSDm
    H&R Quattro coilover
    2007 B7 avant
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    It looks like the spring could go either way so if you're concerned with the nut hitting the spring then I would just swap it around. It sucks because the fronts are no fun.
    Mar 27 2016
    Scandinavia
    Quote Originally Posted by drmonkey View Post
    Right now there is clearance but I haven't put the car on the ground yet, and I wanna make sure it's done right before I drop it down
    Just looking if there are any other people on here that has the same coilovers on the same car :)
    Thanks
    Senior Member Three Rings Gmoney1147's Avatar
    Dec 09 2014
    Roseville California
    Quote Originally Posted by sagafaen View Post
    Thanks
    Personally.. It looks upside down to me.
    Mar 27 2016
    Scandinavia
    Quote Originally Posted by Gmoney1147 View Post
    Should the writing on the springs be upside down then?
    This is how it looks
    http://imgur.com/a/6MhWg
    Mar 27 2016
    Scandinavia
    Here's a better view of it
    http://imgur.com/a/D9Huw
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    I want to say this is upside down. I believe the more coiled part of the spring should be on the bottom.
    Mar 27 2016
    Scandinavia
    Quote Originally Posted by miA4 View Post
    That's what I'm thinking but I can't find any instructions on this and I haven't seen anyone else make a thread about it either so I'm just super confused since it's written on the spring that way so I just assumed
    - - - Updated - - -
    I'm just gonna flip the spring and see what happens
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Spring manufacturers usually intend for their springs to be used the same way their labels are printed on the springs. If you dont know call h&r
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    http://www.hrsprings.com/technical/f...sked-questions
    "2) Which end of the spring is up?
    H&R springs fit the same way that stock springs do. The shape of the spring is most important.
    If the spring is the same on both sides and fits the same either direction, then it is correct to install the spring with the closer coils “up”.
    If the spring is smaller at one end and larger at the other, the orientation should match OEM factory installed springs."
    Also shame on people replying based on "whats looks right" to them. Clearly some good technical opinions to be trusted there.
    2018 A5 S-Line Manual
    Mar 27 2016
    Scandinavia
    Quote Originally Posted by konarider94 View Post
    Wow. Why did I not think of going onto their website, I just searched for instructions on google.
    So I did it right the first time!
    Thanks alot man!
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    It makes more sense to me to have the denser coils upwards. That way there is less unsprung weight which, theoretically, would result in better suspension response.
