It's time to part ways with my 2000 Audi S4. This is a rare color combination. Nagaro blue with blue suede. This is the v6 twin turbo. Car has treated me well.
*Stage 2+ by EPL
*forge diverter valves
*piggy pipes
*AWE twin 2 exhaust
*Coil conversion mod. uses 2012 coils that work better than stock and no longer has ICM's
* Turbos replaced around 90000 miles
* timing belt replaced a second time at 165000 (trying to find receipt)
* new RS4 clutch and dual mass flywheel (175000) Have receipt
* Full Polk MM sound system with 5 channel amp driving all speakers and 12 inch sub with Bluetooth Kenwood deck
* Brakes were replaced around 160000 miles (pads and rotors)
* all 12 pieces of the front control arms replaced
* new center display(no lines)
*Has a small oil leak on the passenger side turbo
*Currently will not pass DEQ because of tune
Text or email me if you have any questions
Just had a pre purchase done and this is whats was found:
Inspection done by Double J Motorwerks, LLC
During inspection found heater core hose is leaking on driver
side.
Passenger front outer CV boot is torn.
Passenger side turbo is leaking out of the housing.
Fuel filter appears to be very old. (ive replaced this)
Wiper blades are worn.
Both side mirrors have bad glass.
Scanned ECU and found 1 stored fault code.
-17865 Exhaust gas temp sensor 2. Short to plus.
Front brakes have 6mm of brake pad left.
Rear brakes have 4mm brake pad left.
Brake fluid is clean.
Tires are in good shape and wearing even.
No transmission leaks found.
No power steering leaks found.
Exhaust system in good shape.
All suspension components look good.
Battery tests good.
No trades
Asking $5000 OBO
mainphoto.jpg2016-09-14 21.58.04.jpgAttach16_20160810_132211.jpgDSC05242.jpgAttachment 28593
