Results 1 to 11 of 11
    Sep 12 2016
    Reno
    Has Anyone Gotten A Warranty To Pay For The Timing Chain?
    This is for the 4.2 V8 folks...
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    Not to sure about anyone else, but here is one case:
    http://www.audizine.com/forum/showth...ut-of-Warranty
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    timing chain/guides would generally be considered a maintenance item... unless it was specifically written in some of the more expensive warranties and can be proven to be a "failure" and not just maintenance issue...
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Aug 09 2012
    Bay Area
    Quote Originally Posted by TarlCabot View Post
    With timing belts or tensioners those i'd consider wear and tear item/maintenance but IMO timing chain shouldn't be. Even though ours are wear and tear
    May 02 2015
    2007 S4 DTM
    WA
    Why would these not be considered an internally lubricated part? These are not parts that are not easily replaced or accessed like a oil filter, or a fuel filter, brake pads, etc... Out of curiosity, I'll call my warranty co tomorrow & ask.
    "The last of the V8 Interceptors... a piece of history!"
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    insurance/warranty companies DO their research on these cars... they know the expense and problems and generally make sure to write these as not covered (they try to make money not lose)
    try calling a few and tell them what car you have them ask specific questions about... What If ???
    if they say its covered ask them to email you the docs on that...
    they will either tell you that they are unable to sell you a warranty for your car or it would be in the 5 to 7k price range
    you would also have to be able to prove all oil changes at 3k miles and all maintenance has been done by certified mechanic and THEN will have to have all damaged parts shipped to them to verify including the oil... its crazy :(
    PAST
    Current
    May 02 2015
    2007 S4 DTM
    WA
    Just out of curiosity, I called my warranty company today, & spoke with the rep about the timing chains, and tensioners. If they failed and need to be replaced, they would be covered.
    You are correct, they know what car's they're dealing with and what the common concerns are. Yes, for major repairs they may ask for maint records (would not even be a concern), not uncommon.
    I've yet to mail parts back, unless there is a core charge.
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    So, if my car has changed hands a few times, how do I find maintenance records for it? and how do I know if mine falls under the recall for the timing chain? 04 S4
    Jan 14 2009
    Audi's
    Quote Originally Posted by Terry.Reese View Post
    I would think if a previous owner shelled out 10k for a timing service they would have kept a record of it .....
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    there is no recall for timing chain ???
    PAST
    Current
    Aug 09 2012
    Bay Area
    You might be able to get away by saying that previous owner has no maint record. Also I don't believe there is a recall for the timing chain. I definitely would have known as my shop has done about 5 already.
