Results 1 to 2 of 2
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    FS: NEW high performance AAN/urS big turbo build parts--UPDATED LIST - No Longer Available
    Selling all of my car parts. No more time for projects.
    1. AAN block bored .5mm over. Also
    has been hot tanked, honed, & decked.
    Includes a polished aan crankshaft. Price
    is $800 + shipping. Shipping is not bad
    through freight companies.
    2. Good condition AAN head. No cracks in
    the combustion chamber and it has good valve
    guides. Valve seats have been reground
    as well. The only flaw is a tiny crack on
    the passenger front side of head where the
    valve cover mates to the head. Not crucial
    as no compression is held there. This head
    has been pressure tested & verified before
    machine work was performed- The head has
    also been decked- Price is $600 shipped.
    3. Custom JE pistons. Took 5 weeks to arrive.
    Price is $625 shipped. Specs below:
    Bore: 81.5mm
    Stroke: 86.4mm
    Comp: 9.5:1 good for pump, E85, & race gas tunes
    Coatings: None
    Wrist pins: Base JE's
    4. Integrated Engineering 5cyl rods- SOLD!
    5. Issam/FRP plug & play AAN Fluidampr- SOLD!
    6. 034 tilton twin disc kit- $1500 shipped
    Contains the following:
    A. 034 5cyl tilton aluminum flywheel- cost $695 before shipping
    B. Tilton twin ceramettallic clutch kit- cost $920 before shipping
    C. 034 Tilton throwout bearing- cost $175 before shipping
    D. 034 tilton pilot bearing
    E. 034 hardware
    7. Supertech dual valve spring & titanium retainer kit-
    $375 shipped
    8. New INA stock weight lifters- $107 shipped
    9. 034 billet cylinder head freeze plug-
    10. New aan check valve- $27 shipped
    11. New IROZ 3" AAN downpipe- for aan
    cars with turbos with v-band
    discharge- price is $350 shipped
    12. New from the dealer inner aan timing
    belt cover- SOLD!
    13. New turbo return nipple- $27 shipped
    14. AAN OEM metal thermostat housing
    15. 034 billet coolant flange ---- ALL 3 for $150 shipped
    16. New OEM upper block coolant nipple
    17. New ARP headstuds- SOLD!
    18. Victor Reinz top end reseal kit- SOLD!
    19. ACL race rod bearings calico coated +0.001" - SOLD!
    20. 034 coated main bearings- SOLD!
    21. ACL main bearing (non coated, stock size)- $75 shipped
    22. Sand blasted mint aan windage tray- $75 shipped
    23. Sand blasted aan oil pan- $100 shipped
    24. Refrurbished motor mount brackets- $100 shipped obo
    25. Refurbished coolant pipes. $100 shipped for all 3
    26. Refurbished snub mount bracket- $50 shipped
    27. 034 urS snub mount & bracket- $50 shipped
    28. NEW TRW urS front control arms with AK motorsports
    track poly bushings installed in them- price is $200 shipped
    29. Factory serpentine belt for Euro urS
    cars with no a/c. --- SOLD!
    30. Issam INA billet crankcase breather- SOLD!
    31. Custom made -6an turbo block
    coolant return port- $50 shipped
    32. 034 aan stainless valve cover hardware- $27 shipped
    33. Sand blasted oil filter housing- $50 shipped
    34. Factory GKN urS axle core set all 4 - $250 + shipping
    35. New factory aan main bolts,wrist pin
    clips, and dampener 24mm center bolt- SOLD!
    36. two aan valve covers- $50 + $19 for shipping
    37. urS to ev14 injector adapters- $25 shipped
    38. urs6 headlight washer delete trims- $65 shipped
    39. custom made air leather urS e-brake handle- $65 shipped
    40. urs4 euro headlight glass- $125 shipped FIRM
    41. MOMO early audi aftermarket steering wheel hub-
    Price is $64 shipped
    42. New genuine leather urS e-brake boot- $35 shipped
    43. 3 new urs6 front grill badges- $100 shipped a piece.
    You will not find these anywhere.
    44. 3 new s6 plus steering wheel badges- $50 shipped a piece
    45. 1 audi sport steering wheel badge (new)- $100 shipped
    Rare find
    46. good condition stock AAN damper- $150 shipped
    47. Supertech 5cyl valve stem seals- $65 shipped
    List Date: 9/15/2016
    For more info, click here to view the original listing: FS: NEW high performance AAN/urS big turbo build parts--UPDATED LIST
    This item is no longer available.
    Nov 14 2013
    Updated the list again.
