Results 1 to 40 of 45
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    Audi B8 S5 - V6 3.0 TFSI Eventuri intake system under development
    Hey guys - as most of you know - us RS5 guys love the system.....Eventuri is now working on one for S5 owners.....all sales will be handled by forum sponsors who sell Eventuri :)
    See below...
    With the success of our B8 RS5 system and buoyed from the great feedback and support we received from Audizine forum members - it's time we visited the B8 S5 V6.
    Having learnt a great deal from the RS5 development - it was clear from the outset that this had to be another sealed system. The heat soak generated in the engine bay would simply negate and power gains from a free flowing filter system. Worse still - perhaps even reduce power compared with the stock system. Unfortunately many intakes currently available for this platform are open to heat soak - many have produced what seems at first glance to be sealed but on closer inspection do not seal the filter to the stock intake duct leaving it open to draw hot air in from the engine bay. Furthermore - open cone filters with heat shields also draw in hot air because the shields are not fully sealed and the cone does not directly draw in air from the duct. There is minimal airflow being forced into the duct as it terminates well above the grill.
    The Stock System
    Unlike the small stock airboxes in the RS5, the S5 airbox is a decent size which draws in air from the duct that terminates behind the front grill. The stock filter itself is cylindrical and so has plenty of surface area however the airflow path is not so smooth. Parts of the stock filter are shrouded closely by the airbox and airflow has to negotiate through several turns before ending up at the throttle body. Since the airbox is mounted to the chassis - the inlet tube has to be flexible to allow for engine movement - therefore contains ridges which are also not great for smooth airflow.
    The Eventuri Design
    As we did with the RS5 - the main component in our intake system will be our Patent Pending Eventuri filter housing. This provides a smooth transition from the filter opening to the inlet tube to maintain laminar airflow through the system. Another feature of our venturi design is the increase of gas speeds at the housing exit which allows for better throttle response.
    Here is a diagram explaining how our filter housing is so different to anything else out there:
    The effect this has on a supercharger is a reduction in drag due to the laminar flow which allows the charger to work more efficiently therefore resulting in more power.
    Unlike many "carbon" intakes, we will be using 100% prepreg carbon fibre and plenty of it! Our housing will have a 2mm wall thickness which is unheard of in this industry. This means that the carbon will be a very effective insulator from the high heat of the engine bay.
    The filter housing will connect to a carbon tube which will gradually reduce in diameter from the housing exit to the throttle body - matched at both ends.
    Finally and perhaps the most challenging part is the cold air feed. This will be 2 components, the duct and the scoop. Our duct will connect to the stock duct and then smoothly transition to the circular filter opening of the housing. It will be fully sealed to the stock duct and again sealed to the filter housing. Finally a scoop protruding down from the stock duct behind the grill will force ambient air upwards and into the intake system to ensure low IATs.
    Initial CAD Models
    More updates to follow...........
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Jan 12 2011
    2016 Q5, 2018 S90
    This will be gorgeous
    Really regret just picking up an intake now
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    I have no reservations endorsing Eventuri...noticeable tire spinning power in the RS5.
    Can wait to see the development dynos and the final product for the S5...nothing but quality.
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Sep 28 2010
    NW NC / DE
    Awesome! Excited to move some :)
    Please mention the SQ5 as well. Honestly, I see more performance thirsty SQ5 owners compared to S5.
    Veteran Member Three Rings Johnhanson's Avatar
    Oct 26 2013
    Regina
    I've been snooping around the M5/6 boards and these guys are moving tons of these in FI cars now. It seems like the go to intake for the guys running 7-800 hp tunes.
    I'd be pumped if I was an S5 guy.
    2013 Audi RS5 Coupe | Phantom Black | Everything except ceramics | Capristo | Eventuri | 15/10 H&R | Rotors when it's cold | V-Spokes when it's warm
    2015 BMW X5 35d Msport | it runs on kerosene | notsport | baby seat
    dead and gone.....
    2012 BMW X6 50i | it had a bike rack
    2010 Ram 1500 | hhhhemi
    2008 Mazda RX-8 | it go-karts
    2006 Infiniti G35 coupe | my lady
    1998 Eagle Talon esi | no turbo powers
    Nov 28 2015
    Montreal, QC
    Now, I don't want to be an ass, but it has been proven on PLENTY PLENTY dyno, for OVER 6 YEARS, that open-element provide approx. 10-14whp on a stg2 car. Like plennnnnnntyyyy of times, from all around the world, on different tunes.
    and you... you come and say that open-element RUBS power ? really ? Like the brit would say, thats a lot of rubbish ! lol
    S4 B8.5 no track, just enjoying spirited driving.
    Oct 26 2013
    Regina
    ^ Engrish prease
    dead and gone.....
    Oct 09 2008
    This'll be good when it hits the S4 crowd.
    The Awesome™
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Deleted
    Apr 26 2005
    Houston
    To answer some questions:
    For the SQ5 - it seems like it will fit but we need to verify this once the intake is ready.
    The open cone filter: Putting an open cone filter in the S5 engine bay will reduce the restriction on the supercharger however, the S5 engine bay gets very hot and with the bonnet closed an open cone filter will only draw in this heated air. So the benefit of higher flow becomes negated with the higher IAT as you have lower air density entering the combustion.
    Dyno tests often are done with bonnets open which does not represent what happens on the road. Our system uses a cone filter and so has the advantage of higher flow but for this application we have designed it as a sealed system otherwise as soon as the engine bay is heat soaked the gains are eaten away. We have tested this many times on different applications, both NA and FI. We always dyno with the bonnet closed and we have consistently found that an open system might give some initial gains while the engine bay is cool but the gains are quickly eroded on consecutive dyno pulls as the engine bay heats up. You might still retain some overall power gain on the S5 but it won't be as much as when the cone was pulling in cooler air before heat soak. Some of our systems are open BUT in these instances we use a highly effective cold air feed system to saturate the filter opening with cold air.
    So in summary - our system has the advantages of an open system in terms of flow restriction by using our Venturi housing, but also has the advantage of a closed system for low IATs.
    It should fit the S4 as well......to be confirmed.
    • eCode headlights
    • Eventuri intake
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by JamesRS5 View Post
    Breathing engine bay temperature air defeats the object of a good induction kit. I'm sure you see good results on a dyno with the hood open but close it up and you're breathing air that's hot so low in oxygen and harder to compress, not beneficial to performance.
    A sealed intake breathing ambient air directed from the front grille will always be at an advantage over an open system.
    Looking forward to seeing the results from this one.
    i would 110% agree with you if i didn't see otherwise in the S4 Forum.. its not just dyno.. they have actually logged and determined that the open design makes more power on this platform..
    they have logged 3 closed systems and the Roc Euro, CTS and the stock airbox mod and the open keeps the IAT's lower .. here is the airbox thread
    http://www.audizine.com/forum/showth...x-hole-testing
    don't be so quick to discredit waxxon though this theory i've seen hold true on most cars it doesn't hold true for the s4/s5 and he has done/participated in many performance threads in the S4 Forum.. he knows his shit about this platform
    i am curious however to see the results of this intake to see if it will be better than the open designs
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Sep 28 2010
    NW NC / DE
    Chris - I meant to say 3.0 Q5 as well.
    Feb 27 2014
    Dubai
    Quote Originally Posted by doug97gxe View Post
    Not discrediting anyone and I apologise if it came across that way, just trying to clear up the open and closed intake differences. Hopefully this will be a 'best of both' and give good results.
    Nov 10 2014
    Apex, NC
    no worries.. but yeah its weird and its why Roc-Euro even with their customer service issues have so much business, because their design has proven to make the most power and keep the IAT's lower.. i don't understand it.. it isn't suppose to make sense but can't beat the logging
    Present:
    Apr 26 2005
    Houston
    From Eventuri...
    "I had a look at the thread mentioned regarding lower IATs on an open system but I could only see pressure measurements. On an open system the absolute pressure will be higher but IAT will also be higher. An open cone has no choice but to draw in air from the heated engine bay. "
    • eCode headlights
    • Eventuri intake
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by chrissurfr View Post
    From Eventuri...
    If they can lower IAT's, make power and look half as good as the RS5 intake the S4 forum will eat it up like hot cakes
    Sent from my iPhone8s using Tapatalk
    Present:
    Apr 26 2005
    Houston
    Update.....
    We will be logging the intake system and stock airbox with VAG-COM to measure IATs and MAF values. The aim is to keep IATs low while increasing the values for airflow volume. We will also do some comparison logging for the IATs between the sealed design we have VS an open design (we will remove the duct which will expose the filter).
    To enable the filter to breath better we have added a second air feed to the duct. This inlet is at the base of the duct to which we will attach an 80mm diameter flexi hose and guide it under the headlamp where the temperatures are ambient. This additional inlet ensures the filter is able to draw ambient air without the restriction of just breathing from the stock duct area.
    Here is a render of the duct design showing the secondary inlet port.
    • eCode headlights
    • Eventuri intake
    Dec 28 2005
    NY/NJ
    looks like eventuri posted a dyno...
    Current: 2024 SQ7, 2021 RS5
    Oct 26 2013
    Regina
    I would expect a bit better "max hp" number. But look down low and up to 25 ft lb? Nice.
    dead and gone.....
    Apr 26 2005
    Houston
    Update..........
    With the design complete we were able to do some before and after dyno tests. In order to realise the gains from the intake, the S5 needed a remap so that any extra boost pressure was not bled away. The car we used had a smaller pulley and stage 2 remap upgrade and we tested it with the stock airbox first, then with the Eventuri intake. The only change between runs was the intake system. Both tests had the remap and pulley upgrade. Here is the Dyno and the video we captured during the live test.
    Dyno was carried out on a Dyno Dynamics system with the bonnet closed for both stock and Eventuri systems. This is important because leaving the bonnet open does not represent road conditions.
    As can be seen, in the low to mid RPM range there is a healthy gain in torque between 25ft-lb and 34ft-lb. This gain is instantly noticeable on the road with the car pulling away more aggressively and having better throttle response. In the higher RPM range where power takes over from torque, there is a decent gain of 19hp to 22hp with a peak RPM gain of approximately 17hp.
    The gains are from a combination of reasons:
    1) The sealed system keeps IATs low - especially with the front air scoop which forces air into the system.
    2) The Venturi housing provides a smooth transition from the filter to the intake tube which maintains laminar flow. This helps the charger to run more efficiently.
    3) The entire system is constructed from pure pre-preg carbon fibre which is great at insulating from heat.
    The owner of the car was very happy with the way the car drove after the intake - his own words "it feels like a different car, pulls so much better off the line and keeps pulling relentlessly".
    Here are some photos of the system installed (scoop photos to follow).
    We will be logging temperature and MAF values next week to show a comparison between this system, the stock airbox and this system without the duct and scoop to make it effectively an open cone.
    The intake is currently under production and availability will be in the next 4-5 weeks.
    • eCode headlights
    • Eventuri intake
    Jul 23 2016
    2006 Lincoln Navigator
    Tacoma, WA
    Would the 3.0T application fit 4.2L V8 in B8 S5?
    Apr 26 2005
    Houston
    Quote Originally Posted by Benzo1133 View Post
    doubt it...
    • eCode headlights
    • Eventuri intake
    Sep 28 2010
    NW NC / DE
    I'm excited! They'll move WAY more of these than the 4.2 RS ones.
    Funny seeing a B8 nose. I suppose it is a cab.
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    It threw me for a loop too.
    2010 Ibis White Audi A4 P+ l Upgrades: RS4 grill, Akebono Brakes, Debadged, Solo Werks S1 Coilovers, Targa Trophy Stickers(guaranteed 10+ HP) l
    2009 Ibis White Audi S5 Coupe | Upgrades: RS Grille |
    Established Member Two Rings konst86's Avatar
    Aug 24 2016
    RUSSIA
    How much cost this intake?
    Audi A4 B8.5 REV0
    Jun 22 2015
    UK
    Hi guys - just though I'd share this from the S4 thread here too......
    Allow me to introduce myself - I am Bilal, the lead design engineer at Eventuri and I thought it would be best to try and answer your questions directly. Please be aware that I may not be able to browse and respond quickly all the time as we are currently working on the new RS6 system so I will have periods where I won't have time to even eat!
    I appreciate some of you have modified your airboxes and some are using components from different brands - I particularly like the comment above regarding the step down issue on using silicon tubes - exactly right! This issue is one of my biggest gripes with companies using silicon tubes over turbos and throttle bodies as they expose a thick rim causing turbulence. on this particular intake our carbon tube inner diameter matches the inner diameter of the throttle inlet and the silicon coupler just keeps them together. Furthermore - upstream, the ID of the tube matches the ID of the filter housing which is a larger diameter and so the tube itself also tapers down linearly to the engine.
    In terms of the power gains - I see a lot of you are quoting around 20hp but missing a more important gain and characteristic of the graph - the low-mid range torque. Have a look at the uplift in the torque curve - in particular the low-mid range rpm where the gain is up to 34ft-lb. Too often we get hung up about the "end figure" but the area under the graph gives you a better indication of how the car will drive and this is a significant gain in torque which means the car drives significantly better in terms of performance and response. Here it is again:
    I have read some comments about low IATs on an open cone system which is strange because the S5 engine bay gets HOT!! - the thread which was linked to show measurements only showed absolute pressure measurements - not temps. Apologies if I missed this but would love to see measurements showing lower IATs with an open cone vs a sealed system. There is always a balance to be achieved in designing an intake - IAT vs volumetric airflow. Clearly an open system will allow for more flow but at the cost of higher IAT - so we spend a lot of time and effort in attaining low IAT and ensuring as smooth an unrestricted flow as possible.
    Comparative tests: We will be logging IATs and MAF values shortly with our system VS the stock airbox VS an open system (our inlet tube with just an open cone filter on the end). We won't be logging other brands, it is not good ethics for us to do this but you guys are free to do so.
    Uprated heat exchangers: We haven't had the opportunity to try our scoop with an aftermarket HX - however if someone could send me some photos of their HX from the top, so remove the plastic slam panel cover and take a photo straight down, then I can assess the fitment. Please PM me or email [email protected]
    As you have seen - our systems are fabricated from prepreg carbon fibre. This means they are great for heat insulation, beautiful to behold BUT obviously are priced accordingly. Even so, for the number of carbon components and the quality of our work, our pricing is very competitive in comparison with other "carbon" systems (not fibre-glass overlaid with carbon!). Since we do not produce huge numbers of systems and have a select number of dealers, this also means the residual value of our systems remain very high. Pricing is currently being finalised and will be announced soon.
    I hope that answers some questions and we look forward to launching this system for you to experience.
    Bilal
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    what about the 4.2 S5 guys?
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by wxsgt View Post
    the cost for performance would not be worth it.. the 3.0T is seeing 34 lbs of TQ increase.. you guys would struggle to see 10
    Present:
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    well guess it's back to just waiting till I can get the super, or a turbo setup if anyone makes one lol
    Sent from my SM-G920P using Tapatalk
    Nov 10 2014
    Apex, NC
    http://www.audizine.com/forum/showth...percharger-Kit
    Present:
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    that's the one I'm saving for unless a turbo kit comes out. sorry my wording was off its early lol
    Mar 28 2016
    It would be interesting to view results on a totally stock B8 3.0T S5.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by Poppe View Post
    i'm willing to bet that most of the people who are stock are not going to spend this amount of money on an intake. You buy this intake you want ultimate performance and looks.. so your target market is going to be Stage 2 cars, so the time on R&D on a stock car is almost a waste of time
    Present:
    Established Member Two Rings doc280's Avatar
    Feb 09 2016
    NC
    I would be willing to bet there are many people here who have not felt comfortable doing a stage 1, much less a stage 2, but are running some type of intake upgrade, whether it be for performance, sound or looks.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by doc280 View Post
    I'm willing to bet they are, but they are running $200 intakes not comfortable doing an intake that could be $1000 .. if TD1 is the concern with not being comfortable doing Stage 1/2 the wrong SA can manually TD1 you for an intake as well.. it has happened
    Present:
    Feb 27 2014
    Dubai
    If I can pull 21hp out of a stock RS5 then I'm sure the stock supercharged S5 will make healthy gains too, that mid range torque increase is something I dream of!
    Sep 28 2010
    NW NC / DE
    I think the point was missed. I believe Poppe was simply saying it would be interesting to see what type of gains the intake would generate without any supporting mods. See exactly what the intake alone brings to the table. He was not assuming that would be a common scenario.
    Nov 10 2014
    Apex, NC
    yeah i get that, but i was just assuming the time and research they have to get this product live they wouldn't bother testing a scenario which would be small percentage of the people purchasing. even if the car has EPL or Unitronic and you can flash without going to a dealer (APR or GIAC) you will have to drive a couple days to adjust the tune to get a true stock or true stage 2 ECU adjustment
    Present:
    Sep 28 2010
    NW NC / DE
    It's not about testing a scenario, but the product to see what it alone is capable of. The same could be said for catback+DP, trans mount+ full mount pack, coilovers+sways/links. Whatevers Douglas. <3
    Nov 10 2014
    Apex, NC
    Lol
    Present:
